Dewalt laser with trouble.
  • playman
    • Jan 2011
    • 252
    Hello.
    I have a Dewalt laser DW087
    http://www.dewalt.com/tools/lasers--...rs-dw087k.aspx
    The problem with it when I got it, was that there were no lights on it.
    I opened it and noticed 2 wires were loose, they were not insulated
    and sometimes they touched the skeleton and that would turn off the laser.
    So I switched them with 2 wires I had (red and white)
    now I don't have the problem with it turning off, with out me wanting it of course.
    The problem now is the horizontal line is really dim while the vertical line is
    really bright (like it should be)
    I tried to switch the red and white wire, wich did not change anything.
    So the trouble must be on this board I pictured.
    The 2 Potentiometers do nothing, as it seemed.
    So I ask, what could be my problem?
    please bear in mind that I have no clue about it's age or it's usage, but could
    it be the laser "bulb" itself that's griefing me?
    I apologise for the picture quality, but I used my phone to take the picture.
    A link where zooming option is enabled https://www.box.com/s/p3ki8obgeou8x7ntvnj2
  • redwire
    • 3912
    Re: Dewalt laser with trouble.
    It's hard to tell from that pic, but I see two (duplicate) regulator circuits, one for each laser diode (the three-pin parts). The trimpots are to adjust laser power output. It's the same circuit that laser pointers use.
    Just rough guessing, but the loose wires probably damaged things or you have them connected to the wrong spots. Laser diodes do not like too much juice and the dim one is probably damaged. They are easy to buy on eBay or DX if you want to change it out. But I'm not sure why the trimpots do nothing. They should affect brightness. Are the batteries old? Or a transistor might be shorted.
    Some info from a hardcore laser guy:
    Don Klipstein laser website
    • playman
      • Jan 2011
      • 252
      Thank you for the reply redwire.
      After some time tinkering with the device, I managed to "brake" the other laser as well.
      So now they are equally dim, trimpots still don't do anything, and the batteries are new.
      I might be able to overcharge the lasers just long enough to check out the 3d scanner
      project. Similar to this one http://lifehacker.com/5822730/make-a...-some-software
      Thank you for your time and the link, it's quite interesting
      • Mohammad Hameed
        • Oct 2022
        • 8
        • Iraq
        Hi guys. I have a Dewalt laser DW088. I need the datasheet of the ic which used to drive the laser diode. Please, does anyone have a schematic for this device?
        • redwire
          • 3912
          No IC's, just dual transistors MBT3946
          It's not hard to sketch a schematic. It is the same constant-current circuit for each laser diode.
          So the same circuit twice- you can compare readings or test the transistors with a multimeter.
          • Mohammad Hameed
            • Oct 2022
            • 8
            • Iraq
            Thank you very much for the quick response (redwire) and thank you very much for the datasheet. I did not know the ic number and I knew it from you. This will help me in understanding the electrical circuit used to operate the laser diode.
            • Mohammad Hameed
              • Oct 2022
              • 8
              • Iraq
              Please, I need the part number of the laser diode used in Dewalt laser DW088. Is it possible to replace this laser diode (LD and PD) with a laser diode (LD) that has two pins only?
              • Mohammad Hameed
                • Oct 2022
                • 8
                • Iraq
                Please, I need the code number (part number) of the laser diode used in DW088 laser level. Does anyone know the code number (part number) of the laser diode used in DW088 laser level?
                • Mohammad Hameed
                  • Oct 2022
                  • 8
                  • Iraq
                  Please, I need the datasheet of the laser diode used in DW088 laser level. https://drive.google.com/file/d/1yLJ...usp=share_link
                  • Mohammad Hameed
                    • Oct 2022
                    • 8
                    • Iraq
                    • redwire
                      • 3912
                      I cannot find any data on the laser diode with 7ABG, B054 markings. Expensive and special high power it would be made by Sharp.
                      There are many generic laser diodes in same size TO-5/9mm can. It might be a smaller TO-18/5.6mm can, you have to measure it.
                      These are cheap: https://www.aliexpress.com/item/1005004090484473.html
                      Another part's data https://www.aixiz.com/store/product_...roducts_id/234
                      Or take apart laser pointers. I just changed to using a Bosch green laser level and it is much brighter than red.
                      • Mohammad Hameed
                        • Oct 2022
                        • 8
                        • Iraq
                        Thank you so much. You did what you could. I reiterate my thanks and appreciation to you and your suggestions.
                        • dansity
                          Power DeWalt 12V laser measure from power supply
                          by dansity
                          i got a Dewalt laser measure which uses the 12V batteries to operate. The laser measure is faulty and I want to attempt a repair, never fixed such thing before. You might see a different topic if I fail with the repair
                          However I do not have dewalt batteries nor want to buy one for 140EUR as the laser tool might have some chance that it is very hard to repair or unrepairable.
                          I want to power it from my PSU.
                          The tool has 3 input pins, on the battery it is marked with B-, B+ and ID/TH.
                          i want to know what is the third pin exactly and what do I need...
                          10-29-2023, 03:04 AM
                        • Dannyx
                          Hilti PD30 Laser Range meter Error 276
                          by Dannyx
                          Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
                          So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
                          07-30-2023, 05:05 AM
                        • snipersquad100
                          Dewalt DCR020 Power Board – No Power, Need Help Identifying ICs / Possible Replacement
                          by snipersquad100
                          I’m working on a Dewalt DCR020 jobsite radio that won’t power on.
                          So far, I’ve checked the following:
                          • The mains is reaching the transformer
                          • Transformer outputs ~15-20 V AC
                          • Bridge rectifier outputs ~15-20 V DC
                          • All fuses test OK
                          • The on/off button signal reaches the PCB connector
                          Despite this, the unit does not power up at all.
                          Inside, I’ve identified some of the ICs:
                          • ST7317 (appears to be an LCD driver, not the main MCU)
                          • LM2937L (voltage regulator)Not putting out power, 0.5V on the input
                          • Markings like FS1235, unknown IC
                          • Board number:
                          09-01-2025, 10:57 AM
                        • Dannyx
                          Wire twisting tool for small wires - ideas ?
                          by Dannyx
                          Good day folks. Recently, I started doing more and more alarm system installs which involve dealing with a ton of small wires which are part of 4 to 12 core alarm cable. To make my installs as clean and neat as possible, I twist together the individual wires whenever possible to make braids like in the picture. It takes a lot of time and wears on my fingers really quickly, to the point where I actually developed a blister on my index finger from all the twisting. This got me thinking if there's a tool designed to braid small wires like this. I know there is something for twisting together solid...
                          08-23-2020, 06:29 AM
                          I would like an explanation of how a laser can measure a product on a conveyor belt
                          by sam_sam_sam
                          I saw this on
                          “How do they do it “
                          The laser was measuring the diameter and the height of the product and the weight of the product and it was a straight line laser light across the the conveyor belt ( this is all that was shown in the video clip of the laser that was used )
                          What type of product is this that can do this
                          I want to thank anyone that knows what of laser this is
                          04-24-2022, 07:55 AM
