Mains Transformers Power Ratings
  • barry wilkins
    • Aug 2009
    • 172
    I have a Newnes Engineering Data book 1951 .
    There is a mains transformer table in it ,if I look up 230volts 50 cps (Hz) it says a constant of 1840 divided by the size of the transformer core in square inches .So a small transformer say .5 by.5 inches = .25 sq inches = 7360 turns.
    Obviously there is more to a transformer than this ,how do you work out the core size in regards to the power required ?. I know the wire sizes are determined by the current capacity of the wire ( thicker the better) and the number of turns you can actually fit on the bobbins.
    Does any body have any easy tranformer info. that can help me.
    Barry Wilkins
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Mains Transformers Power Ratings
    Barry Wilkins
    Take a look at this great page!
    -Ben
    Muh-soggy-knee
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      Speaking winding coils, anyone seen how a machine toroid winder works, even for a small number of turns? Winding by hand would be a major PITA and have to go with a bobbin + split core (for high freq)/EI system(for low frequency)...
      • redwire
        • Dec 2010
        • 3912
        Transformer design is really complicated, although they are constructed quite simply. Everything is a trade-off with something else and the math can be intense. In the 1950's they ran (AC mains) transformers quite conservative, they kept everything really simple and over-designed.
        Operating magnetic field strength (flux density) and frequency sets power output. If you push the core harder, it can be smaller in size (saves $) but runs hotter due to eddy current losses. There are several different types of steel laminations, some better than others. Another trade off is a smaller core being able to fit the windings that you need.
        There's some good info here, the excel spreadsheet calcs help: http://ludens.cl/Electron/trafos/trafos.html
        • barry wilkins
          • Aug 2009
          • 172
          I have a small hand winder ,its actually a grindstone about 30 years old and has a 9 to 1 ratio OK for little coils and the like .I dont wind many coils these days ,but I do need to make an inverter for my caravan lights.
          Barry
          • barry wilkins
            • Aug 2009
            • 172
            Thank for the info ,I did read quite a good article on the internet,but there is something wrong with the final equation .I need to work on it.
            I have been trying to make a new lamp inverter for my caravan as the ones that came with it fail very quickly .I just cant understand how they get away with such a small transformer with so few turns on it . I dont think there any shorted turns in the transformers but the units draw an awful ammont of current !
            I have made a unit with a design a saw on the internet that uses a ferrite rod ,this used a single transistor ,but my circuit is push pull not exactly like the Royer design but close.
            This is performing very well driving two lamps in series about 25W and drawing around 1/2 Amp at 14volts.
            The only draw back it is a bit big (about 3 times).Also the flyback across the transistors is very large it can easily kill the BUX 85 trnasistors I am usuing.
            Anyway I have ordered an E133 core on ebay ,when I have some spare time I will try to design a much neater one.
            Barry Wilkins
            • redwire
              • Dec 2010
              • 3912
              Barry, it sounds like you have a saturated-core oscillator for your fluorescent inverter. I find these have a couple transistors and a tiny transformer. Since the transformer is driven to its max. (then) causing the transistors to switch, it really does get the most from the transformer. Frequency also changes based on the load. Lowest-cost circuit but it does mid-efficiency, since the transformer is run hard and the transistors don't switch cleanly.
              A bit more here: http://ludens.cl/Electron/Fluolamp/fluolamp.html
              • learnmore
                Help choosing replacement transformer for Levoit 600S SMPS
                by learnmore
                Hello Community,
                I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                Peace
                LM...
                11-04-2025, 09:35 AM
              • amelbye
                is it ok to replace a dual output transformer with two single output transformers?
                by amelbye
                Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
                Now that's a challenge - luckily...
                08-21-2020, 08:51 AM
              • ohren
                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                by ohren
                Hello!
                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                Measured voltages with no load:
                After rectifier diodes
                12V: 6.17 V
                5V: 5.67 V
                Secondary transformer pins AC measurement (really don't know if this says anything)
                12V: 2-2.5 V
                5V: 1.04 V
                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                03-18-2023, 10:33 AM
              • dicky96
                Laminator blows fuses and trips the mains - but not when on my ispolation transformer
                by dicky96
                Hi guys
                So here is a 'weird device' it is an IKON IP-450 A2 Paper laminator
                The customer says it was warming up then suddenly tripped out the 220V mains
                He replaced the 5A fuse which had blown but it did the same thing straight away as soon as powered on, it trips out the power in his apartment. He tried another power lead and tried it at a friends address but the same occurs
                So he brought it to me, having fitted a new fuse again.
                I plugged it in and it worked fine - it was drawing about 3Amps and warmed up to maximum working temperature...
                05-26-2020, 05:24 AM
              • mikey5791
                Is it possible for transformer substitution?
                by mikey5791
                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                My questions are
                1. How do i test to see if the transformer is in good working condition?
                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                Hope you guys understand what i was asking. My intention is...
                11-03-2022, 02:11 AM
