So I live in an old house in Seattle (From the 1920's) and I had my main rig plugged into the same surge protector as the mini fridge. Every time the fridge would turn on or off, I'll hear a small pop from my computer speakers when they're on and occasionally my mouse will freeze for a second. I moved the fridge plugin to directly into the wall and it still does that same thing to the surge protector plugged in directly below it. I have a high quality power supply but wondering if my fridge is hurting my computer?
Think my fridge might be causing small power spikes?
Re: Think my fridge might be causing small power spikes?
Do the outlet has ground receptacle? The compressor kicking on and off can put big spike into power line. You may try installing another surge suppressor for the fridge. The surge suppressor only clamp down the spike with typical let through of about 330V.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Thanks for the reply. Yeah the outlets do have a ground pin. I may just have to buy a separate surge protector for the fridge?Comment
Try plugging in your pc speakers in another outlet around the house to see how far the spike travels in your house wiring.
May be the arc suppressor RC network or plain cap across the power switch for the compressor had failed. When the switch open, you will get a lot of inductive kickback voltage.
It is best to get rid of the noise at the source.Last edited by budm; 11-09-2012, 01:31 AM.Never stop learning
Second, protectors are not designed for frequent surges. They are designed for rare transients that might occur once every seven years. If your refrigerator is created so many spikes so often, then you may have to replace that tiny (and $80) protector more than once per year. (And its indicator light will not report that type of failure.)
Third, a 1920 house? So two wire circuits are connected to a three prong receptacles? (Inspection starts inside the breaker box.) Not only might that create your computer noise problem (that does no hardware damage). But it also is a human safety threat and a code violation.Comment
I see too many houses that don't have enough proper three-prong outlets.
Luckily, I have outlets that are up to code in my bedroom.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Inductive kickback voltage can easily be 1000V range but only last for microseconds.
http://www.youtube.com/watch?v=oXgfuikGegE
http://www.coilgun.info/theoryinduct...vekickback.htm
There should be a snubber on the switch for the compressor : http://en.wikipedia.org/wiki/Snubber
http://www.wisc-online.com/objects/V...spx?ID=ACE5803
Just Google Inductive kickback.Last edited by budm; 11-09-2012, 09:44 PM.Never stop learning
I also remember reading in Upgrading and Repairing PCs about a seminar where the audience were forced to wear stockings because the venue (a hotel) had improper grounding and therefore computer equipment was sensitive to such improper wiring and crashed under certain circumstances if the audience was not wearing such clothing.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
I agree with budm, open the fridge and put an arc suppressor across the relay!
My dell dimension has no issues when the fan (multi speed control) is turned on. But the harmon/kardon spearkers love to pop and crackle when the switch is turned on or off.
You should check your house wiring, to see if it has a [good] ground.
Go to the store and get an outlet tester, they come in handy!
PS I love old houses!Muh-soggy-kneeComment
Your fridge could cause spikes and/or voltage sags when its compressor kicks in and spikes when it kicks out. Another thing it could do is broadcast bursts of RF at kick-on and -off, which could be picked up in your computer's audio circuit. If your fridge is within 10 or 15 feet of your computer, that may be what you are hearing. Put a battery powered AM radio near your fridge and see if you hear the "pop". If you do, you have been hearing broadcast RF noise and your ccomputer is probably safe. If you put the radio too near your computer the noise from the switching power supply could drown out noise from the fridge.PeteS in CA
****************************Comment
As budm's video notes, to create 1000 volt spikes means a capacitor that is also at 1000 volts. A 1000 volt capacitor installed to make a spike? 1000 volts inside that refrigerator would probably destroy any internal capacitor and even wire insulation. Assuming a capacitor even exists. Even sparking across a switch would cause its switch to destroy itself. If the refrigerator is creating spikes that high, then, as Budm notes, the solution must be installed inside the refrigerator. To also protect that refrigerator from itself.
A spike is only noise that causes no damage. If a spike is on AC mains, then any decent power supply would make it irrelevant. Any decent supply must have filtering many tens of times superior to a filter insode a power strip. (Criticism of Monster are too tame.) If a spike is entering via some other wire (ie inferior supply powering speakers, via safety ground, etc), then a solution starts by first identifying that input path. PeteS' radio is also a useful tool.
Refrigerator is creating noise. Some also eliminate that noise by modifying the refrigerator (ie an RC snubber on its power switch).Comment
I have a window AC unit on the same circuit as a bookshelf stereo and a PC. Every time the window AC shuts off the bookshelf stereo pops. Both have been running like this for over 6 years, I do nothing about it because I'm usually not in the room to hear it and they're not valuable equipment. If I ever get really really bored I might try to clamp the spike at 200V or something.
PC power supplies usually have no surge protection inside.Comment
Every appliance has surge protection. How often do you replace dimmer switches because an air conditioner switched off? Never? Long before PCs existed, 120 volt electronics were designed to withstand up to 600 volt spikes without damage. Today's electronics are even more robust.
This 120 volt UPS outputs 200 volt square waves with a spike of up to 270 volts when in battery backup mode. Why is that ideal power for computers. All electronics already contain protection that even makes 'dirty' UPS power irrelevant.
Protection already inside a stereo means that spike is only noise. How often are digital clocks, smoke detectors, and nite lites being destroyed when a minifridge or vacuum cleaner power cycles? Never. Protection routinely inside each means that spike is only noise. All computer supplies contained internal protection long before the PC existed. Noise causes no damage.
How often does a spike from any appliance destroy the GFCI? Even GFCIs contain robust internal protection.Comment
^ They (often but not always) survive surges merely because the period was short enough and the components needed in non-surge conditions for proper operation, had a bit of voltage headroom.
Most have few if any components commonly associated with surge protection circuits nor do they attempt to shunt the surge to earth ground. PC power supplies for example may have PFC circuitry for its inherent benefit in operation as well as inrush current limiting, output over-voltage protection, but no MOVs, avalanche diodes, gas discharge tubes, etc., and PC PSU are far more complex than the average clock, smoke detector, or vacuum cleaner power supply circuit.
In the typical stereo you have wall outlet -> fuse -> transformer -> bridge rectifier -> bulk DC power rail capacitor bank -> parallel power amp circuit and regulated preamp/buffer audio signal input circuit. Again none of the components commonly associated with surge protection are present. Where is the surge protection there except to pick diodes with as high a voltage rating as the budget and space allows? That only spares the diodes, the fuse cannot react in time to protect against typical short period surges.Last edited by 999999999; 11-11-2012, 01:44 PM.Comment
Second, today 120 volts is significantly filtered; seriously reducing or eliminating spikes. Then converted to a higher voltage (over 300 volt) radio frequency spikes. Even noisy AC is converted to a higher and 'dirtier' voltage. Then superior filters, galvanic isolation, etc convert that intentionally made 'dirtiest' power into rock solid and cleanest low voltage DC. Why? Best protection and superior filters, already inside electronics, must clean 'intentionally made much dirtier' power.
Third, that outlest > fuse > transformer ... example was obsolete technology so many decades ago. Protection, that existed even back then, was not as robust.
Fourth, naive is to assume protection is only provided by a protector device. But that myth is popular. Instead, even datasheets for an interface semiconductor make obvious that myth. Semiconductor will withstand 15,000 volts once part of a circuit:
Fifth, topic is about noise from a mini-fridge. Probably only tens of volts. Usually made completely irrelevant by how supplies are designed. Noise typically must bypass superior protection already inside that supply. And definitely is not hardware destructive.
Listed were possible reasons for noise (including wiring in violation of code - a possible human safety problem). How to solve noise at its source. First identify a reason for noise. Then eliminate at its source what is only noise.Comment
Need to learn more? Not all semiconductor has built-in ESD/ or spike protection that can handle 10KV or more.
even in 12v system can have high spike;
http://www.glseq.com/surge.htm
http://www.idxinc.com/carwash/AppNote101.htm
http://books.google.com/books?id=E9n...120vac&f=falseNever stop learning
What? No, they don't. That's why the stereo makes the popping noise, because a surge makes it to the power amp stage. You're essentially suggesting that every component in everything provides surge protection which would eliminate the notion of surge protected equipment vs equipment that does not have surge protection built into the design.
Why would one need to solve a surge at its source if the device had surge protection built in? Because it doesn't.Last edited by 999999999; 11-11-2012, 08:01 PM.Comment
Your reply should be discussing point 5 that said, "Fifth, topic is about noise from a mini-fridge."Comment
You guys keep thinking this is an issue with surges, but it isn't.
The sparks - when the compressor relay closes and opens its' contacts - make RF interference which travels through the AC wires in your house. The wires act like an antenna. The wires of your computer speakers are acting as an antenna, picking up these bursts of EMR. The small voltage induced in the wires is amplified by the amplifier in the speakers, and you hear a small 'pop' sound.
A surge protector usually doesn't even have an EMI filter. I suggest that you add an EMI filter where the cord goes into the back of the fridge.Muh-soggy-kneeComment
This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:44 PM
This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 03:36 PM
This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-12-2024, 03:28 PM
- Loading...
