250V AC Capacitor across input
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Re: 250V AC Capacitor across input
    Originally posted by budm
    So basically the diagram was wrong? What does the correct diagram look like?
    No No.... the first image I posted was the image from the manual... I photoshopped the second image to represent the circuit as it was after I jumped out the switch / fuse / cap / inrush limiter... I thought it might help people to understand / visualize the changes I'd made, but obviously it didnt work.
    This is the original schematic, to which I have marked in red the section of wire that was open..
    It is still working today, so I think we're good.. Thanks to everybody who helped... A lot of useful information..
      So it is working with the switch bypassed? If that wire is open, you still should have 230V across the Cap.
      • JonathanAnon
        • Jul 2012
        • 457
        • Ireland
        After I put the new wire between TL1 and F2 (marked in the schema above), it worked immediately. I reintroduced all of the original components into the circuit and it is still working.. i.e. the circuit now is the same as the schema in my original post with just the wire between TL1 and F2 replaced..
          That does not explain why you were only getting 30V since you have the cap which is in series with the resistor (10 Ohms thermistor) and connected across the line, then the step down transformer, and then the lamp circuits which are also across the line. So basically you have 3 circuits across the line, you can remove any one of them by opening up the wire you then still should have 230v across the other 2 circuits. The voltage reading was not logical at all.
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • ugamazing
            820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
            by ugamazing
            So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
            1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
            2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
            04-10-2024, 08:06 AM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • chth96
            by chth96
            12-22-2023, 04:34 AM
          • chth96
            by chth96
            06-02-2024, 07:31 PM
