When the MOSFETs go!!!
  • davmax
    • Dec 2005
    • 899
    Often the MOSFETs of the motherboard VRM will be damaged by fault caps. It is hard to find good replacements. Here is where a D2PAK replacement can be obtained:
    http://www.mouser.com/search/Product...ualkey51210000
    and here is the data sheet:
    http://www.fairchildsemi.com/ds/FD/FDB7030L.pdf
    Now we need to find a DPAK version. I will start looking but will welcome inputs.
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: When the MOSFETs go!!!
    i rob them from otherwise scrap boards.
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      General guidelines for crossing to near equivalents, preferably:
      * Equal or higher V(br);
      * Equal or higher I(max);
      * Equal or lower R(D-S On);
      * Equal or lower R(theta j-c);
      * Equal or lower Gate capacitance or Gate charge;
      * If the original is called "Logic Level" it must be replaced with a "Logic Level" device.
      PeteS in CA
      • davmax
        • Dec 2005
        • 899
        Thanks PeteS for the great guidelines.
        The specific device choice I have offered will cover all D2PAK replacement needs. A suffix L device (logic level) will cover all applications and this device is an L product that has low gate charge and low ON resistance R(D-S On), sufficient V(br), high current rating Id and the heat normally generated in these switches is low so that the thermal resistance (theta j-c) is relative unimportant.
        Still have to find a DPAK device.
        Thanks kc8adu a very good solution that can have risk to the devices during removal for the inexperienced.
        Nvidia 8500GT 256Mb
        33 way card reader
        Windows XP Pro SP3
        • davmax
          • Dec 2005
          • 899
          The information can now be completed.
          D2PAK is 10 mm in width (FDB7030L as above). Being replaced by FDB 8896.
          DPAK is 6.5 mm in width and FDD6680AS will do this job. It can be bought from Fairchild Direct.
          In fact all can be bought from Fairchild Direct.
          For those in foriegn countries like Trodas it might be best for another member to buy for them and post onward.
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • BlackScreen_22
            Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
            by BlackScreen_22
            Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
            Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
            I had no problems connecting mosfets and capacitors,...
            08-27-2024, 12:46 PM
          • kotel studios
            Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
            by kotel studios
            Finally got time to fix this board up.
            At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
            Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
            04-22-2025, 05:08 AM
          • flerre
            Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
            by flerre
            Hi!
            Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
            No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
            So, could I safely assume all of these 3 mosfets are...
            03-13-2022, 12:14 PM
          • DrDos
            kenwood kr-6030 Mosfets?????
            by DrDos
            Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
            09-20-2025, 04:42 PM
          • piernov
            NVidia bumpgate
            by piernov
            Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
            Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
            May complete this post at a later date with more details.
            Basically issue is a combination of thermal dissipation of the chip with hotspot,...
            03-27-2021, 10:34 AM
