Help Repairing Music Instrument
  • ivtec
    • Dec 2008
    • 1967
    Hi guys i have a Music instrument keyboard Technics Kn2000,that i few years ago have shorten the audio line out on the Left Chan,because of shorted cables.
    last year i decided to repair it and i did repared it by changing Trans. A1015 and the left Chan on line out was working again,but since then when i switch on the power, it powers up but some times with no sound,i have to push power switch off and on button one more time or two times and some time 3.Besides that it works great,
    I posted sime pics of the circuit where i swaped the tran,A1015 should i look at anything else besises the transistor it self, that might not be the right specs i found this one on my electronic components scrap. thanks in advance.
  • h0m3w0rk
    Repairing a Music Store Professional GO! SUB 18A
    by h0m3w0rk
    I'm working on repairing a Music Store Professional GO! SUB 18A bass subwoofer, and I need some help troubleshooting an issue with the power amplifier board. The board uses an IR2153 driver and originally had two SLW20N50C MOSFETs. Unfortunately, these MOSFETs burned out. I replaced them with two TK20J60W MOSFETs; however, these also failed almost immediately.
    Here are some details:
    • SLW20N50C (original):
      • Rated for 500 V
      • Typical RDS(ON): 0.21 Ω
      • Continuous Drain Current: 20 A at 25°C (13 A at 100°C)
      • Pulsed Drain Current: 80 A
      • Avalanche
    02-27-2025, 07:42 AM
  • CapLeaker
    Fender Acoustasonic 100 / 150 repair
    by CapLeaker
    Got this Fender Acoustasonic 100 in for repair.
    Complaint: Supposedly does strange things, the instrument channel goes pop, crackle, no audio then all of the sudden works again?
    Well... Open this 15 year old sucker up and I am greeted with leaking capacitors. I changed these out, cleaned the board and no audio out of the instrument channel, but some weirdness is gone and sounds now clean on the second channel. So I put my laptop on there and cranked the music full tilt. Sure enough, it goes crackle and pop with the bass in rhythm. Put my signal geni on it and sure...
    07-26-2025, 02:06 PM
  • pecman
    Aiwa Z-R700 Music System has very low power when switched on, dim lighting and nothing works
    by pecman
    I was given an Aiwa Z-R700 from the 1990s era to look at by someone who said the twin tape deck did not work. The whole unit unit powered up ok but there was nothing from the tape deck. I had a look and found all the belts broken, I replaced the belts and then put the tape deck back into place and it still does not work. Also when I now power up the unit all the lighting on the front is very dim and the cd player and the tuner as well as the tape deck do not work. I have checked all the connections and ribbon cables again, there are no burnt or swollen capacitors. Maybe there are capacitors on...
    08-05-2025, 10:10 AM
  • alloverme
    Texas Instrument Datasheet TPS51486RJER
    by alloverme
    i have an issue with my laptop, i troubleshoot and i think i have some issues with this chip, i would like to understand how it work and wich voltage i should have output but i cant find the datasheet
    The chip is TPS51486RJER
    The input 13v and 5v are good but i have strange output 4.5V and i should have 1.2V and 2.5 V
    My post about my issue join
    thanks
    Hello, I have an HP 15-eh0001nf with a start issue, First it didnt start at all power button blinking blue and no screen, but seems a boot loop* I tried to remove most component - > same issueI see some little corroded component, clean them with isopropyle alcool and resamble all -> it worked during less than one
    07-20-2025, 10:08 AM
  • JayPoorJay
    Glueing Two Sided Flex Ribbon,Jaguar XJS Instrument cluster.
    by JayPoorJay
    Hello All.
    I'm working on the printed flex circuit board (flexible type) of a 1990 Jaguar XJS Instrument cluster. If you Google that you'll be able to get a general idea.
    In areas, the plastic has come apart allowing the copper strip to kinda flop around and be exposed to the elements.
    What can I use to glue the 2 faces of the plastic material together trapping the copper ribbon inside...
    Again - thank you all for you help. This will be the 4th or 5th time now that I have come here to receive AMAZING advise and directions. Thanks so...
    05-03-2022, 09:56 AM
