Not quite an electronics question, but I figure there are quite a few of you here that have done car bodywork repair, so I don't think should be okay.
About a month ago, I found this microwave near a trash can about. Nice stainless steel front look and overall in good shape externally. Unfortunately, the original owner must have spilled something inside and probably left it there for a while because the whole back of the microwave chamber has started to rust. I actually posted about this in the "Dumpster Finds" thread, so more info and some pictures can be seen in these posts:
https://www.badcaps.net/forum/showpo...&postcount=250
https://www.badcaps.net/forum/showpo...&postcount=257
Yesterday, I decided to cut out the back because it really is completely rusted in a lot of places. There are still some areas with heavy rust, so I'll probably end up cutting out those as well. Pics below show all of the rust damage after the back was removed.
Now, I am thinking of bolting on a new piece of steel sheet on the back. Home Depot sells 12"x24" sheets fairly cheap - around $10. The only question I have is, which kind should I get? Currently, they have regular steel sheet, galvanized steel sheet, and aluminum sheet. They all cost about the same. Any reason not to get the galvanized or aluminum sheet? I figure those would be better since they wouldn't rust as easily as regular steel and maybe I can even get away without having to buy that special microwave paint (although I probably will just to make it look right)?
Also, what thickness should I get? I'm thinking anything will do. Or is there certain thickness needed to block the microwaves from leaking outside?
 Use dielectric grease where the two surfaces lap over, both to prevent rust as well as 'shocking surprises.'
 Use dielectric grease where the two surfaces lap over, both to prevent rust as well as 'shocking surprises.' .
