I need help finding this part 50117 C-G - TO - 252
+ More Options
Posts
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    I need help finding this part 50117 - TO - 252
    I searched Digikey, Allied, and Fairchild electronics and nothing. 50117 = 5V - 3.3V Regulator
    C = 2.5V
    G = Green Package - not important - I dont think.
    I need it in a TO-252 package.
    Here is the PDF for it.
  • mariushm
    • May 2011
    • 3799
    Re: I need help finding this part 50117 C-G - TO - 252
    C = 2.5V
    So does it says on it C on the chip to determine it's 2.5v or it's the plain 3.3v version? Either way, if it's the one with the 3 pins and on the board the first pin is not connected to ground, then it's adjustable so it doesn't matter.
    The chip is a linear voltage regulator that may have a fixed setting from factory, but can also be adjusted if that adjust pin is not connected to ground. If you see C on the chip or it says 50117-25 or something like that, it's the 2.5v preset version. If you see K or -33 it's the one with fixed 3.3v output.
    If the first pin is connected to ground, it means the chip will use the preset output voltage set inside. If the first pin goes to a trace that has some resistors, then those resistors set the output voltage and you can use any adjustable voltage regulator with low enough voltage drop to work at 5v input.
    If there's no C or K or you don't see 25 or 33 on the IC, that means the voltage is actually adjusted on the board using that adjust pin, which means you can use any low drop voltage regulator in to-252 package, that has a voltage drop low enough to work at 5v.
    So go on digikey, filter by to-252 , positive fixed or adjustable, If you want select voltage out = 3.3v or 2.5v (i'm not sure if you have 2.5v or 3.3v version) , current 1A and more, in stock
    Then when you look at the parts' datasheets, make sure the voltage drop is less than 5v-3.3v = 1.7v (majority of the ldos are 1.1-1.25v drop so you won't have problems finding)
    these will probably work (double check) for 5v to 3.3v - all three default to 3.3v if the adjust pin is connected to ground on your pcb, or to whatever resistance is on the adjust pin so they work at any voltage above 4.5v or so:
    http://www.digikey.com/product-detai...ICT-ND/1301516 (ignore the minimum of 6.3v input listed on page, it needs minimum 4.8v to do 3.3v out, says so in the datasheet)
    http://www.digikey.com/product-detai...ICT-ND/2095619
    ... and so on.
    One more thing you should check is if the tab is ground or Vout on the old part - the datasheet doesn't say or I don't see. On the ones above the tab is Vout...
    later edit:
    here's the 5v to 2.5v versions (to match what you need if it has C on it) :
    http://www.digikey.com/product-detai...SCT-ND/2121233
    http://www.digikey.com/product-detai...GCT-ND/2122996
    • snowfun
      • Aug 2012
      • 21
      • Portugal
      I,
      See in Farnell site all regulaters LM1117 series and find what you need.
      Cps.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Thanks guys for your info. I will try to purchase tomorrow. Here is a pic of the chip but I now have all the info I need, thanks to your help.
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          Originally posted by snowfun
          I,
          Cps.
          The chip you suggest's output current is 800mA. It may work but this one that died was capable of 1A. I dont know what it saw when it died but... I'll look for 1A again.
          • mariushm
            • May 2011
            • 3799
            The datasheet says typical current limit 1200mA, minimum 800mA, when the voltage drop is 5v. You won't have quite 5v drop in the circuit as it does 2.5 from 5v or something around that value, but the IC would probably still do 1000mA or whereabouts.
            0.8A is more or less the guaranteed minimum value for which the regulator will stay within the parameters they advertise (max 0.2% line regulation, max 0.4% load regulation)
            However, this 800mA is a limit that depends on the manufacturer. The same 1117 chip made by others is rated for 1A or 1.5A - see the links I recommended a few posts above, they're also 1117 but made by other companies and they're rated for 1A or more.
            Anyway, at 0.3-0.5$ a piece, it's not worth risking it, just pick one from another manufacturer or another IC that has fixed 2.5v output at min 1A.
            • Duncanbest
              • Jul 2012
              • 81
              • Taiwan
              Maybe LDO 1084 series with package TO-252 will easy fit your requirement,but higher price.
              http://www.digikey.com/?curr=USD
              search ldo 1084
              • selldoor
                Slow Learner
                • 7870
                If you can wait for a slow boat
                http://www.ebay.co.uk/itm/1PCS-AZ111...item19d3c4074e
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  I have an order on it's way from Digikey. Thanks to all who helped. Now I'm just playing the waiting game. I gotta do some house chores to keep busy.
                  • KYBOSH
                    Help finding datasheet for TO-220 Alpha & Omega Semi part# BN7515
                    by KYBOSH
                    Not sure if this is the right forum but i have this one part and i cant find any info on it.
                    Alpha & Omega Semi part# BN7515.
                    It has been sitting on my desk for a while but google has not hits.
                    Can anyine help?
                    thanks in advance
                    04-22-2025, 09:25 AM
                  • G-Sting
                    iPad Pro A1876 SHORT Part Identify Help Needed
                    by G-Sting
                    So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                    So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                    i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                    SO My main concern is what part should i order what should i search the name for ?
                    on Ipad...
                    05-15-2025, 09:30 AM
                  • edugimeno
                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                    by edugimeno
                    Hi There!
                    I'm trying to help my friend who owns a restaurant be just bought.
                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                    09-05-2024, 09:34 AM
                  • chickenhawk88
                    Help finding part number
                    by chickenhawk88
                    I need help trying to figure out these components.
                    1. There is large “Q” almost looks like Qualcomm, FA7808 or FA7608, 2039CC
                    2. This chip has marking of VE with 5 pins.
                    3. This chip has marking eHCSN.
                    Thanks for helping. Im trying to fix laptop motherboard and not having much luck.
                    05-14-2024, 04:00 PM
                  • Yanleb
                    Panasonic part number in service manuals
                    by Yanleb
                    In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                    This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                    For an example, look at the attached PDF.
                    Do you have a way to cross reference the Panasonic part number with the actual part number?
                    Thanks....
                    07-03-2023, 08:16 PM
