Testing a leaky diode
  • Mr Bill
    • Nov 2011
    • 648
    What methods are there? I can test it with my multimeter in the diode function but is that good enough? I came across this link that suggests using a 9v battery.
    http://www.ehow.com/how_7549053_test-leaky-diodes.html
    Is this a sufficient method, or is there a better way of doing it? And can this be done in circuit?
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Testing a leaky diode
    Not while the diode is in circuit because the 9 volts might find other current paths.
    I don't think the article mentioned schottky diodes. These will have some reverse leakage. I just measured one at 10uA.
    I use the ohm range on my Fluke DMM for power supply diodes. I find that diodes used in power circuits either test good or obviously bad. The exception again are schottky diodes with a normal reverse leakage resistance. I just measured one at 15KΩ.
    Also schottky diodes will show a forward resistance reading on a DMM where silicon diodes tend to read open.
    I think this is why there is a diode test range to test the forward bias voltage drop of silicon diodes.
    • Baste
      MBR3045CT and SR3045LCT Schottky diode testing help.
      by Baste
      Hello experts,
      Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
      Aneng ST182 Meter.
      Diode mode.
      MBR3045CT:
      Diode mode
      Pin 2-1 - 0.150v
      Pin 2-3 - 0.150v ...
      10-21-2025, 06:14 AM
    • iyas132
      Corsair RM 750 blown schottky diode near ES1DF
      by iyas132
      Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
      Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
      My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
      Can anyone help me identify the component...
      12-30-2024, 01:34 AM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • spleenharvester
      Brother DCP-L2500D - completely dead
      by spleenharvester
      Hi everyone
      I have quite a bit of experience with low voltage circuits but basically none with high voltage circuits outside of recapping. So if anyone could point me in the right direction I would appreciate it very much!
      This printer, history unknown, has no signs of life when plugged into 240VAC. It has the LT2988-001 board common to many Brother HL-2XXX series printers. The only physical abnormality observed is a green tint to the positive leg on the main 400V filter capacitor. This model is prone to shorts across the four Schottky diodes but all are testing OK by...
      03-01-2025, 08:58 AM
    • Dvsr
      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
      by Dvsr
      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
      After replacing the caps I started testing out the speaker. It seemed...
      09-10-2025, 10:20 AM
