Indentify those caps
  • blazer249
    • May 2012
    • 6
    I have a Forsa Nvidia Geforce 9600GT with those caps:
    - ULR 16V 330 YC;
    - ULR 4V 1200 YC;
    - FZ78 1000 6,3V;
    - 928 sep 330 16.
    Can someone help me please indentify those caps?
    Thank you very much!
  • Rulycat
    • Apr 2010
    • 724
    Re: Indentify those caps
    FZ78 is Sacon FZ. Crap cap. If it's already blown it would have made a loud pop, if it's not, it will soon! Others will be along shortly to give you advice on a higher-quality replacement cap.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Originally posted by blazer249
      - ULR 16V 330 YC;
      - ULR 4V 1200 YC;
      Samxon X-CON ULR (solid polymer)
      - FZ78 1000 6,3V;
      Sacon FZ. Replace on sight. Most likely the reason why you're posting this lol
      - 928 sep 330 16.
      Sounds like Sanyo SEP series solid polymer
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        I just replaced some fZ's on three xfx 8600's two days ago. ALL popped. Same model.
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
