Will placing caps in series double their voltage rating?
  • TechShui
    • Jun 2011
    • 148
    And placing them in parallel doubles their capacitance?
  • mariushm
    • May 2011
    • 3799
    Re: Will placing caps in series double their voltage rating?
    Yes, provided they're the same voltage and capacity rating. When in series it's often recommended to connect resistors in parallel to balance the voltage on the capacitors and to drain them when the circuit is disconnected.
    See this: http://www.aikenamps.com/AddingComponents.htm
      Remember though two caps in series have half the effective capacitance.
      • TechShui
        • Jun 2011
        • 148
        Thanks for the tips guys, I'll try this out
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          And putting two equal caps in series doubles their effective impedance.
          PeteS in CA
          • Ratjaws
            • May 2012
            If I recall my CET schooling correctly I don't think connecting capacitors in series will increase their voltage rating. Correct me if I'm wrong but that rating is the maximum voltage before damage to the device becomes probable. While their effective impedience becomes less and therefore the voltage drop across them is less, the absolute voltage rating does not change. Placing two 120 volt caps in a series circuit should allow you to safely place 240 volts across the whole but the actual maximum remains unchanged. So my sense of this question says no, placing caps in series will not change their voltage rating.
            Ratjaws@aol.com 051712
            • PeteS in CA
              • Aug 2005
              • 3579
              Well, if you think of the input circuit of a non-PFC P/S set for 240VAC, after the bridge rectifier you have two 200V capacitors in series. If 240VAC is applied, there is ~335V across those two capacitors. So clearly series-connecting capacitors of equal value and equal maximum voltage increases themaximum voltage of the circuit. Further, I have worked with P/S companies and in P/S groups for nearly 30 years, so far. I know that the design maximum AC voltage for such an input circuit is 264VAC, a DC voltaage across the capacitors of ~370V, or nearly double the 200V rating of tthe capacitors (and don't forget that electrolytic capacitors have a capacitance tolerance of +/-20%).
              PeteS in CA
              • daftpunker
                • 5
                You are right. The voltage ratings of capacitor can`t be changed simply by putting them in series. What you accomplish by doing this is to divide the voltage potential among these capacitors. Since the parts might degrade at different rates, they might experience a different voltage level. In the worst case one part fails early and depending on the type of capacitor used the failure mode might be a short which forces the entire voltage drop across the non-failed capacitor.
                the voltage rating is based on the life tests conducted by capacitor manufacturers that allows them to estimate the minimum life of capacitors under maximum operating conditions.
                  by momaka
                  03-12-2025, 03:42 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • Perry Babin
                  Operating caps well below rated voltage
                  by Perry Babin
                  I think this has been answered but I couldn't find the thread.
                  Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                  So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                  If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                  Or would it require reforming?
                  05-23-2024, 05:43 PM
                • quickname
                  Cyberpower 1500AVR UPS repair
                  by quickname
                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                  Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                  I decided to verify that the batteries were...
                  11-12-2023, 09:57 AM
                • SwedishDiesel
                  Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                  by SwedishDiesel
                  Howdy folks,
                  I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                  10-30-2021, 12:47 AM
