D-Link DIR615
  • Amraks
    • Nov 2011
    • 725
    Re: D-Link DIR615
    sorry the 0.01's are caps but the ones reading 0.00 are diodes.
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      #42
      Re: D-Link DIR615
      unfortunately, you can only be sure of the diodes removing them and measuring off the board. But they are easier to deal with than the ICs.
      • Amraks
        • Nov 2011
        • 725
        Re: D-Link DIR615
        Whats a good tool to remove these little components?
        like to pick them up
        • Amraks
          • Nov 2011
          • 725
          Re: D-Link DIR615
          never mind I have them 2 chips out and tested the resistance at the jacks again still same results
          • Amraks
            • Nov 2011
            • 725
            Re: D-Link DIR615
            M 691 00A3R 806Ad can't even find a replacement on the net for that chip.
            Oh well I guess this is a big waste of time these sort of things.
            But I have learnt lots.
            • rogfanther
              • Jul 2006
              • 458
              • Brazil
              #46
              Re: D-Link DIR615
              well, it seems possible the main processor is toast. It is time to put the thing in the trash and buy a new router.
              • Amraks
                • Nov 2011
                • 725
                Re: D-Link DIR615
                I have plenty of routers just wanted to fix this one to see if you could fix things like this I suppose some you can't and some you can lol.
                I have read posts about zener diodes being toasted on some and some with fuses being toast but seems this didn't have any of that protection the thing is toasted.
                • Amraks
                  • Nov 2011
                  • 725
                  Re: D-Link DIR615
                  PS thanks for helping me.
                  Also I will be taking my caps I will be salvaging what I can off that board I put some new caps on it.
                  Now I have a box for the card reader I made lol
                  • mentholflash
                    • Mar 2013
                    • 36
                    • Western Australia
                    #49
                    Re: D-Link DIR615
                    Originally posted by rogfanther
                    I think they wanted you to test without the fuse to see if the short was after or before the fuse. From experience with a bunch of 615´s that we got to fix, using wrong adapter kills the two regulator ICs.
                    You can let the power supply conected, wait a few minutes and see if they are hot.
                    You can remove them with the air gun, but you should practice in some scrap board first. Note that they are tiny components, and there are other tiny smd resistors and caps around them , that can be easly blown out . I seem to remember they have a GND pad in the underside, so a good amount of heat may be necessary to remove them. Use whatever tool you are confortable working with.
                    To reliably test the diode, you would need to take it out of the circuito, but if it doesn´t give short both ways, or open both ways, it should be good.
                    The chips are not that easy to get, but it is doable. But the cost of components + shipping can be greater then the equipment´s value.
                    hi
                    i have 2 of these routers both with too much voltage added .
                    can you send me a link to a place to buy these regulators
                    thanks
                    • rogfanther
                      • Jul 2006
                      • 458
                      • Brazil
                      #50
                      Re: D-Link DIR615
                      That would be digikey, mouser , Farnell - Element 14 and the like. Those two regulatores I mentioned are very small and fine pitched, so take a look if you feel able to solder them before spending money in new regulators.
                      • mentholflash
                        • Mar 2013
                        • 36
                        • Western Australia
                        #51
                        Re: D-Link DIR615
                        hi
                        i have a rework station but havent used it for a while
                        i know you said they have a ground pole on the underside do i just add heat to the top and wait until free?
                        can you give a part nuber for the regulators as reading them is proving quite hard
                        thanks
                        and thanks for the reply
                        • mentholflash
                          • Mar 2013
                          • 36
                          • Western Australia
                          #52
                          Re: D-Link DIR615
                          hi mate
                          any chance of a link
                          thanks
                          • rogfanther
                            • Jul 2006
                            • 458
                            • Brazil
                            #53
                            Re: D-Link DIR615
                            From my notes, it is a Marvell G3100A3R
                            www.farnell.com
                            www.digikey.com
                            www.mouser.com
                            • mentholflash
                              • Mar 2013
                              • 36
                              • Western Australia
                              #54
                              Re: D-Link DIR615
                              Hi mate
                              sorry to be a pain
                              a search for that item produces no results with any of those suppliers
                              or on marvell site
                              any other info on what to search for
                              ie a descripion the package name
                              thank very greatfull for your help
                              i have aquired 3 of these with the same problem
                              cheers
                              • rogfanther
                                • Jul 2006
                                • 458
                                • Brazil
                                #55
                                Re: D-Link DIR615
                                Only thing I have is this datasheet. Only places selling it were the chinese ones, like Alibaba.com or Aliexpress.com. Considering the price of a new router versus the price for the components, plus shipping, made it economically inviable.
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                  03-31-2024, 02:12 PM
                                  07-01-2024, 06:34 AM
                                • shamsudeen
                                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                  by shamsudeen
                                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                  07-19-2025, 07:14 AM
                                • JimBanville
                                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                  by JimBanville
                                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                  09-13-2023, 07:21 AM
