countin machine - bad capacitor
  • thesloc
    Banned
    • Dec 2011
    • 587
    recently removed a bad cap, SWC 470uF 50V cap (it was blown).
    Would a capacitor rated at 16V work as fine??? I'm saying this because I can't find a capacitor that's 470uF and 50V.
    The cap is rather small.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: countin machine - bad capacitor
    If your voltage is well below 16V, say 12V or lower, then yes. You can use your multimeter to verify. If you get it wrong, the 16V cap will go POP when voltage is applied.
    Digi-key has 470uF 50V cap at
    http://search.digikey.com/us/en/prod...1260-ND/356161
    --- begin sig file ---
    --- end sig file ---
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • Agent24
      Dick Smith Q-1760 linear power supply filter capacitor question
      by Agent24
      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
      It has at least one problem.
      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
      I have already ordered a replacement potentiometer, so that's not an issue.
      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
      All are CapXon...
      10-21-2025, 05:39 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-12-2024, 03:28 PM
