Building a Mouse Zapper
  • Amraks
    • Nov 2011
    • 725
    What I have is a dc 9 volt power pack
    pringles can
    with 2 separate sheets of foil
    one side hooked up with a 450v cap
    the other is just straight to the power pack.
    Will this work or is there more I need to be doing?
  • dmill89
    • Dec 2011
    • 2534
    Re: Building a Mouse Zapper
    You'll need something to boost the voltage. 9VDC won't do much of anything. Remember the 450v rating on the cap is its maximum working voltage (the voltage it can handle before it fails) the actual voltage delivered is determined by the input voltage if you put 9V into a cap you get ~9V out, the design of the circuit and other components determine the voltage delivered, not the caps themselves..
    • Amraks
      • Nov 2011
      • 725
      didn't think of that.
      Now so what would boost it to 450v?
      I'm thinking you need to build a array of something to step it up?
      • Koda
        • Aug 2011
        • 317
        • Macedonia
        inverter
        Guns don't solve problems. I'll take 12
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          *pictures ratdude deleting this thread cause of a love of our rodent friends*
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Depending on what mains voltage is, couldn't you just plug it into the wall socket?
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              You can use the flash circuit from a disposable camera, but beware!
              It will charge up the cap to around 300 volts!
              Also make sure to get the polarity correct, or the cap might explode on you.
              The flash circuit usually runs on 1.5-3V, so powering it with 9v might kill it.
              When you take the flash apart make sure to take the battery out without touching and circuits, then short the capacitor leads with something conductive to discharge the capacitor.
              -Ben
              Muh-soggy-knee
              • severach
                • Aug 2007
                • 1055
                You could buy one:
                Rat Zapper
                sig files are for morons
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  I laughed so hard at that! The video would be interesting, but it wants to download winblows media player 11 to play it....booo!
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • lti
                    • May 2011
                    • 2547
                    The video just looks like a TV commercial. You didn't miss much.
                    • Amraks
                      • Nov 2011
                      • 725
                      youtube the videos of a ratzapper lol
                      I ended up just using a different method one that I don't need to reset.
                      But I think I got all the mice out of my house because I haven't found any in the bucket.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        how to build a mouse zapper:
                        hook a high voltage transformer to its PS2 plug
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          i have one at the shop.
                          made by victor.
                          it works well too.
                          put a dab of peanut butter on the far end.not had the bait stolen in months.they cant get to it alive ;-)
                          • John123john
                            • Sep 2017
                            I also heard about the rat zapper a couple of years ago. I also heard about the Bounce sheets on the Owners Group. If it works I'm there. I finally got rid of the mice with humane traps; they worked better than the sticky traps overall. Rats can't fit into them though and not all sticky traps are not equal. So if i make my own tap, it will work well?
                            • John123john
                              • Sep 2017
                              Anyone have scheme for building rat trap?
                              • brispuss
                                Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                by brispuss
                                Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                12-28-2022, 02:58 AM
                                MSI Infinite A VR7RC-003DE + Gaming Pack Infinite i5-7400 Specification for Upgrade or Repair
                                This specification for the MSI Infinite A VR7RC-003DE + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A VR7RC-003DE + Gaming Pack boardview and Infinite A VR7RC-003DE + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                09-12-2024, 03:28 PM
                                ACER Aspire AspireRevo R3600 + Gaming Pack Aspire 230 Specification for Upgrade or Repair
                                This specification for the ACER Aspire AspireRevo R3600 + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire AspireRevo R3600 + Gaming Pack boardview and Aspire AspireRevo R3600 + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                Acer Aspire A317-53-369X + Pack Gold Acer 17'' Notebook 3 Specification for Upgrade or Repair
                                This specification for the Acer Aspire A317-53-369X + Pack Gold Acer 17'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-369X + Pack Gold Acer 17'' boardview and A317-53-369X + Pack Gold Acer 17'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                09-07-2024, 03:10 AM
                                Acer Swift SF314-511-51KS + Pack Gold Notebook 3 Specification for Upgrade or Repair
                                This specification for the Acer Swift SF314-511-51KS + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-51KS + Pack Gold boardview and SF314-511-51KS + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
