uh oh I messed up.
+ More Options
Posts
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    uh oh I messed up.
    I got two caps with the wrong spacing. They are 7.50mm, holes are 5mm.
    Is there any issues if use them?
  • 999999999
    • Sep 2006
    • 774
    Re: uh oh I messed up.
    They'll just sit off the PCB a little. If it's a single sided board and trace path allows, I would think about drilling a new hole 2.5mm further away, but I've done it before so the practice experience, right sized bits, and a drill press are at my disposal. Better to try these things on worthless PCBs before doing it on valuable ones.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      good I can live with them sitting off a bit, they are 1.49 each. I could order the correct ones but I'll never use the ones I have now.
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        well that sucks, I still have the same problem, but if I unplug the inverter board the TV set stays on.
        Must be a bad transformer or CCFL.
        It's got 7 bulbs and 7 transformers so one of the two.
        • 999999999
          • Sep 2006
          • 774
          It would be easier if you consolidated all issues about a particular repair to the same topic in the (TV?) repair subforum. Not enough info to know exactly what you're facing, presumably a 32" TV that shuts off or won't turn on?
          Initial guess w/o seeing pics or schematic is a shorted transistor, CCFL tubes are just full of gas and if they fail it's not a short circuit... but they're probably plugged into sockets right? So they can be unplugged.
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            I did have a topic, no one answered and that was 3 weeks ago.
            When I plug it in, it works for 2-5 seconds, I see the Phillips logo on the screen then unit goes dead. But if I remove the inverter from the equation the set stays on. So that means something is wrong with the inverter or it's CCFL lamps.
            • 999999999
              • Sep 2006
              • 774
              Bad lamps get dim or won't light, not excess current that shuts down the TV (not the problem). I don't even see pics of the inverter board. This is far too little info and far too fragmented. All needs presented at once in same place at same time or else people get disinterested, probably why you didn't get replies on the previous topic, there wasn't enough info to solve the problem or make suggestions.
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                refer to here
                https://www.badcaps.net/forum/showth...789#post217789
                I shall have pictures of the inverter board up in a moment.
                • gretti
                  MSI Z370-A Pro, works but does not power off or reboot and USB issues
                  by gretti
                  I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                  The MSI BIOS included the ME firmware for the board. The size...
                  10-16-2025, 02:14 AM
                • SoulFreeze
                  Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                  by SoulFreeze
                  Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                  After repairing the above issue, I realized the following remaining problem,
                  Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                  The computer recognizes headphones are connected and displays a popup in windows
                  Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                  06-21-2025, 09:53 AM
                • Nagyesz
                  Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                  by Nagyesz
                  I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                  All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                  How can I extend its lifespan? Could reflow help?
                  It has ryzen 5 5500h, rtx 2050, no soldered ram.
                  Example of the artifacts:
                  03-01-2025, 11:11 AM
                • pwnjuice
                  Bitlocker issues
                  by pwnjuice
                  Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                  Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                  Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                  01-06-2025, 05:33 PM
                • Skgod
                  Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                  by Skgod
                  Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                  Black screen, freeze
                  The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                  When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                  So can anyone tell me what would be the possible cause?...
                  10-16-2024, 08:11 PM
