Metalized polyester film capacitor problem
  • link988
    • Aug 2011
    • 11
    Hi
    I am new to all this electronic repair stuff but gotten around to fixing some of lcd monitors and now decided to takle a plasma tv repair
    I got around to finding that stan by voltage is at 6.5V instead of 9.5V and every time I touch the testing points with digital multi meter for less then a sec multimiter will spike to 9.4V and goes to steady 6.5V. I traced all components along the line and got around to if I am not wrong "metalized polyester film capacitor" and its saying "470n M 275V" on the top and service manual says its suppose to be 470nF but I measured it with dmm and it shows 360nF.
    My question is, are they measured like electrolitic capacitors just put 2 probes to 2 terminals and get the result and does it mean this one is faulty? My dmm can measure up to 50 uF so covers the values needed here.
    And is possible for 3 of them to fail on the power filter board (that from different set)?
    Thank you in advance for any help.
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: Metalized polyester film capacitor problem
    link, the markings you quoted mean that the part is a 470nF (.47uF), +/-20%, 275V capacitor. That voltage rating strikes me as curious. Is there a "~" after the "275"? If there is, that is probably an X capacitor, which is connected from Line to Neutral of the AC line, and thus unlikely to be your problem. Also, it may be polyester dielectric, but it could also be polypropylene, and impregnated paper parts could look similar.
    Getting accurate in-circuit measurements of resistors or capacitors is dubious, even with high-quality handheld DMMs. So I think your measurement basically means that the part is good.
    It sounds to me like that standby voltage is not being regulated, or is being current-limited. If there is an opto-coupler, that may be the problem. Look for a low resistance from the standby output to ground. Check to see if the regulator (or output rectifier) is hot.
    PeteS in CA
    • link988
      • Aug 2011
      • 11
      Thank you for reply.
      I tested the capacitor in circuit first and then soldered it out to test and got the same reading of 360 nF. I allready learned a my lesson of not taking parts out to test them spend the whole day on trying to find the faulty part when it was right in front of me just needed to test it separately. So I guess its dead or on its way there.
      Do all the characteristics of capacitor apply to these ones as well or there is something different about them?
      Is it just the way they made? like more reliable etc.?
      There is a "~" after 274 V ~. Just noticed around the pins where they moulded into the cap there is slight brown colour deposit (other 3 that I was asking about got around 1mm circle around the pins on all of them could it be leaking or its just with age).
      I will just get a new one just to be sure then.
      There is 1 opto-coupler in the stand by circuit will check it out today.
      Thanks.
      • link988
        • Aug 2011
        • 11
        0
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          They are a safety device against power surges.
          The reduced capacitance happens when they successfully stop a power surge from hurting anything else.
          They made to do that without themselves shorting in the process.
          Recommend using the same type cap.
          They will have both a circuit voltage rating and a surge voltage rating.
          I -think- that and capacitance is all you need to know for these.
          Mann-Made Global Warming.
          - Dr Seuss
          • PeteS in CA
            • Aug 2005
            • 3579
            Depends on wht you mean, link. It has capacitance, and it has a maximum voltage. But every dielectric has its peculiar charateristics, and different types of construction have their characteristics. E.g., electrolytics pack a lot of capacitance into a given case size. But 'lytics are polarized, their impedance goes up with low temperature, and cannot operate as cold as other dielectrics. Some ceramics are high capacitance with horrible temperature characteristics; other ceramics are lower value, but quite stable. The cap you are looking at has a good stability dielectric, and is constructed to handle surge voltages safely. I agree with PC, it sounds like that part may have beenn damaged, though .36uF is within the 20% tolerance ... barely. It must be replaced with a similarly rated safety capacitor! And be sure to match the lead spacing before buying the replacement part.
            PeteS in CA
            • PeteS in CA
              • Aug 2005
              • 3579
              I should add, though that I do not think it is the main problem with your power supply.
              PeteS in CA
              • link988
                • Aug 2011
                • 11
                Thank for the help at explaining what that capacitor is and does. Looks like it is not the problem as I found 2 other identical capacitors on the board to be same 355nF and 364nF so my guess if they all would be faulty the TV would not even power up.
                My issue is plug it in the wall stand by red light comes up, switch it on with the remote, then light goes green for about 5 sec and then constantly blinking red until I switch it off (remote doesn't respond on switch off command). The display doesn't light up and no sound.
                Through some internet search I found that if standby voltage is low like in this case then the blinking occurs. There are no bulged capacitors on power board and 9V stand by is 6.5V roughly.
                I am very bad reading schematics and so on but after looking at the one I attached to the post the voltage after the transformer "5500" should be 9V but its 6.5 there, all other voltages like 5V and 3V are there which apparently derived from that 9V and in my case from 6.5V.
                Can it be that the transformer is not completely failed but on the way there?
                Sorry probably should have started another Thread.
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • chth96
                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                  by chth96
                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                  I know that these capacitor will not last as long as nichicon capacitor...
                  12-22-2023, 04:34 AM
                • chth96
                  How can I test non-polarized capacitor?
                  by chth96
                  I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                  I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                  And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                  I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                  06-02-2024, 07:31 PM
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
                • chth96
                  Should I replace polymer capacitor?
                  by chth96
                  a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                  I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                  Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                  Is this ESR value of polymer capacitor correct?...
                  11-18-2022, 04:22 AM
