Solar garden lights with deep discharge protection?
  • japlytic
    • Oct 2005
    • 2086
    I am wondering if there are any solar garden lights which have deep discharge protection for the battery.
    Many solar garden lights do not have deep discharge protection, as far as I know.
  • Francesc V.
    Christmas lights - Something I am doing wrong
    by Francesc V.
    Hi:
    i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
    I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
    If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
    Could...
    03-11-2023, 07:38 AM
  • Techie_hobby1
    Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
    by Techie_hobby1
    Need some help please with a few components on this small board so that I can troubleshoot the circuit.
    The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
    J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
    J2 - to DC Output
    J3 is Battery cell connector
    however I am struggling to identify if:
    Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
    07-24-2025, 12:43 PM
  • bialag
    Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
    by bialag
    I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
    Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
    03-25-2025, 05:56 PM
  • gabrielA7
    IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
    by gabrielA7
    Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
    I saw that the room LED lights up only when the screen is connected, so quiet.
    We have all the power supplies, even processor, 1.8V
    One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
    I suspect that there may be some leak in the processor.
    Anyway, when I press the power, it...
    10-29-2024, 06:48 AM
  • redwire
    Making a capacitor discharge tool
    by redwire
    I'm making a new capacitor discharge tool. Asking for suggestions for sizing the discharge resistor.
    Mr. Carlson's Lab High Voltage Capacitor Discharge Tool 1 is using 4 of 1kΩ 50W aluminum (mount to heatsink) resistors in series for 4kΩ 200W, so it's big, which is fine.
    His Patreon but I don't have a paid subscription for the project details but it looks straightforward. The plastic box with aluminum plate can't get rid of any amount of that heat though.
    Wirewound resistors can be overloaded by a factor of 5 for 5sec. and a factor of 10 for brief times. I've never tried say...
    06-18-2023, 07:09 PM
