SXE Series not recommended for new designs?
  • japlytic
    • Oct 2005
    • 2086
    I stumbled across this page http://www.chemi-con.co.jp/cgi-bin/C...e.cgi?lang=eng and found that the SXE Series were deleted from the catalog, but datasheets were still available, meaning the SXE Series were still in production. Are the SXE Series not recommended for new designs, and are they going to be discontinued in the future? (These were my favourites!)
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: SXE Series not recommended for new designs?
    That is what this means. Like many other vendors, UCC is warning users of the series (I think the KMF series is also being discontinued soon) that they need either to do a lifetime buy or do the work to switch to a more modern series. They also are warning design teams not to design in a part that will soon be discontinued.
    PeteS in CA
    • japlytic
      • Oct 2005
      • 2086
      I think the KY series would most likely replace my favourite SXE series.
      • PeteS in CA
        • Aug 2005
        • 3583
        KY and KZE look like good solid series. KZH looks interesting, too.
        PeteS in CA
        • WeStSiDePLaYa
          • Mar 2006
          • 63
          cant manu's just switch to new series?
          Specs
          DFI AM2 LANPARTY UT NF590 SLI-M2R/G
          X2 3800+EE AM2
          2x1GB OCZ PC2-6400 Platinum XTC
          XFX 7900GS
          Maxtor 6L250S0
          Maxtor 6V300F0
          Western Digital WD2500JS
          Mushkin HP-550(Cap/Filter Modded)
          Cooling
          Swiftech Apogee
          Swiftech MCW-60
          Swiftech MCP-600
          HardwareLabes Black Ice Extreme 2
          • PeteS in CA
            • Aug 2005
            • 3583
            Component engineering and sustaining engineering are a bit more meticulous than that. New parts need to be tested in each existing product. Plus the phase-in needs to be managed properly - if a product has an array of caps in parallel, you probably don't want to mix two different series (e.g. if you mix PSs and HEs of the same C and V ratings, the ripple current sharing will be uneven).
            PeteS in CA
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              many manufacturers do that on vcore - some fujitsu some MCZ etc. will there be a useful improvement to replace the odd ones with same series, or are we just talking about capacitor endurance etc.
              • PeteS in CA
                • Aug 2005
                • 3583
                Re my hypothetical, it was based on a real situation that came up last week where I work, and the array is of identical caps. OTOH, as you point out (and I forgot), there are occasions where designers intentionally select different types, locating them according to their intended function in the circuit (cap networks for handling large magnitude, high di/dt, current transients come to mind).
                PeteS in CA
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  yeh but i am talking about a row of caps on output of vcore. some fujitsu 4v 560uf, some mcz 820uf 6.3v all in parallel.
                  • PeteS in CA
                    • Aug 2005
                    • 3583
                    WestSide's Q was more general. Arrays like what you describe - lytics plus polymers plus MLCCs are chosen and positioned so that the power "system" from the VRM to the uP die will be able handle a high magnitude, very fast current transient. The capacity, impedance and location of each part are chosen to take care of each part of the transient. E.g., low inductance MLCCs are closest to the chip; the lytics close to the VRM handled both the normal ripple current and are an energy reservoir (albeit somewhat slow, compared to the MLCCs) for handling most of the energy demand of the transient. Sun had a computer program to select the quantities of each type, and was even considering, ca. 1998, designing some capacitance into the SPARC processor die to compensate for the inductance inherent in the bondwires.
                    PeteS in CA
                    • japlytic
                      • Oct 2005
                      • 2086
                      I did a comparison to the SXE Series with KY Series units, which I would be inclined to use when the SXE Series are discontinued.
                      • arneson
                        • Sep 2005
                        • 1267
                        It was my dream to do this kind of design 15 years ago.
                        Unfortunately my smarts/education quotient was severely lacking.
                        Jim
                        • japlytic
                          • Oct 2005
                          • 2086
                          Update: http://www.chemi-con.co.jp/english/c.../daigae_e.html
                          SXE Series is discontinued; recommended replacements are KY (as I predicted) and LXV Series.
                          • PeteS in CA
                            • Aug 2005
                            • 3583
                            Unless I wanted the slightly higher ESR or needed a 100V rated part, I'd choose the LXZ series over the LXV - lower ESR and better life rating (5K hours for LXV and 8K hours for LXZ, IIRC).
                            PeteS in CA
                            • yanz
                              • Nov 2004
                              • 910
                              SXE and LXZ are both available in my area. i don't know why i would choose them over the LXZ, but i see lot of them on audio equipment/hardware.
                              i don't like that if company decided to stop the production of certain seies, they decide to delete the datasheets too. sometimes it's impossible at all to find the dataheet for a discontinued product.
                              days are so short when you actually do something..
                                ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                                This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-12-2024, 03:28 PM
                                ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                                This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                                This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                                This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                                This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
