I stumbled across this page http://www.chemi-con.co.jp/cgi-bin/C...e.cgi?lang=eng and found that the SXE Series were deleted from the catalog, but datasheets were still available, meaning the SXE Series were still in production. Are the SXE Series not recommended for new designs, and are they going to be discontinued in the future? (These were my favourites!)
SXE Series not recommended for new designs?
Re: SXE Series not recommended for new designs?
Are the SXE Series not recommended for new designs, and are they going to be discontinued in the future?PeteS in CA
I think the KY series would most likely replace my favourite SXE series.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
KY and KZE look like good solid series. KZH looks interesting, too.PeteS in CA
****************************Comment
Originally posted by PeteS in CAThat is what this means. Like many other vendors, UCC is warning users of the series (I think the KMF series is also being discontinued soon) that they need either to do a lifetime buy or do the work to switch to a more modern series. They also are warning design teams not to design in a part that will soon be discontinued.
cant manu's just switch to new series?Specs
DFI AM2 LANPARTY UT NF590 SLI-M2R/G
X2 3800+EE AM2
2x1GB OCZ PC2-6400 Platinum XTC
XFX 7900GS
Maxtor 6L250S0
Maxtor 6V300F0
Western Digital WD2500JS
Mushkin HP-550(Cap/Filter Modded)
Cooling
Swiftech Apogee
Swiftech MCW-60
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2Comment
Component engineering and sustaining engineering are a bit more meticulous than that. New parts need to be tested in each existing product. Plus the phase-in needs to be managed properly - if a product has an array of caps in parallel, you probably don't want to mix two different series (e.g. if you mix PSs and HEs of the same C and V ratings, the ripple current sharing will be uneven).PeteS in CA
if a product has an array of caps in parallel, you probably don't want to mix two different series (e.g. if you mix PSs and HEs of the same C and V ratings, the ripple current sharing will be uneven).Last edited by willawake; 05-14-2006, 03:34 AM.Comment
Re my hypothetical, it was based on a real situation that came up last week where I work, and the array is of identical caps. OTOH, as you point out (and I forgot), there are occasions where designers intentionally select different types, locating them according to their intended function in the circuit (cap networks for handling large magnitude, high di/dt, current transients come to mind).PeteS in CA
yeh but i am talking about a row of caps on output of vcore. some fujitsu 4v 560uf, some mcz 820uf 6.3v all in parallel.Comment
WestSide's Q was more general. Arrays like what you describe - lytics plus polymers plus MLCCs are chosen and positioned so that the power "system" from the VRM to the uP die will be able handle a high magnitude, very fast current transient. The capacity, impedance and location of each part are chosen to take care of each part of the transient. E.g., low inductance MLCCs are closest to the chip; the lytics close to the VRM handled both the normal ripple current and are an energy reservoir (albeit somewhat slow, compared to the MLCCs) for handling most of the energy demand of the transient. Sun had a computer program to select the quantities of each type, and was even considering, ca. 1998, designing some capacitance into the SPARC processor die to compensate for the inductance inherent in the bondwires.PeteS in CA
I did a comparison to the SXE Series with KY Series units, which I would be inclined to use when the SXE Series are discontinued.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Originally posted by PeteS in CAdesigning some capacitance into the SPARC processor die to compensate for the inductance inherent in the bondwires.
Unfortunately my smarts/education quotient was severely lacking.JimComment
Update: http://www.chemi-con.co.jp/english/c.../daigae_e.html
SXE Series is discontinued; recommended replacements are KY (as I predicted) and LXV Series.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Unless I wanted the slightly higher ESR or needed a 100V rated part, I'd choose the LXZ series over the LXV - lower ESR and better life rating (5K hours for LXV and 8K hours for LXZ, IIRC).PeteS in CA
SXE and LXZ are both available in my area. i don't know why i would choose them over the LXZ, but i see lot of them on audio equipment/hardware.
the SXE Series were deleted from the catalog, but datasheets were still available, meaning the SXE Series were still in production.days are so short when you actually do something..Comment
This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
- Loading...
