Soldering equipment
  • bbjunkie
    • Dec 2011
    • 301
    Soldering equipment
    I'm considering buying something suitable for some intricate soldering, currently i've got a board on which I need to swap an ASIX AX88796 IC. It has a lot of very fine legs. I think hot air may be the only way.
    Suggestions welcome
    Jim
  • mariushm
    • May 2011
    • 3799
    Re: Soldering equipment
    Put solder on the pcb pads or just use liquid paste then use a quality solder iron or hot air gun.
    See to the end: http://www.youtube.com/watch?feature...9fAlfQE#t=839s
    I've recently bought a Hakko 936 and was almost shocked at how easy it was to solder stuff compared to the 35-50w mains powered solder irons.
    However, with a chip that has the pins so close together, I'd probably use hot air and solder paste.
    At 26:50 in the video above it shows how to use hot air gun...
    • retiredcaps
      • Apr 2010
      • 9271
      Another good solder video (only 9 min total).
      http://www.youtube.com/watch?v=3NN7UGWYmBY
      If short on time, start at 5:30.
      --- begin sig file ---
      --- end sig file ---
      • 999999999
        • Sep 2006
        • 774
        Pulling the old chip off will be easier with a hot air station, but since you don't want to try to salvage the chip, you could use a probe or insulated needle/etc to pry up the pins one or a few at a time using a soldering iron, then drag solder the replacement chip on after using desoldering braid to remove all remaining solder.
        Unfortunately Hakko has discontinued their 936 & 937, replacing those with FX-888 (? I think that's the number) and unfortunately a lot of their 9xx series tips for those stations too.
        I suppose my point is, if you don't have a high quality soldering iron yet I would invest in that before only a hot air station since it has more uses over the long run, but if you plan on doing chip swaps like this in the future it is worthwhile to have the hot air station too.
        Hard to tell from the picture exactly how small and tight the pins are though, maybe too tedious to use an iron and needle probe even if possible, especially if the traces to it are long/thin/fragile.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4938
          • New Zealand
          Chipquik or hot air station (you can get basic ones very cheap now) should remove the IC easily.
          For installing the new IC, solder paste and hot air could work, you'd probably have to clean up some bridges though.
          You can also try flood-and-suck method, or with some practice, drag soldering.
          (So says all the videos I've seen on Youtube anyway!)
          -David VanHorn
          • mockingbird
            • Dec 2008
            • 5484
            You _can_ actually solder those in with ordinary solder and an ordinary iron, it's not easy, but I've done something like that. I don't recommend it.
            • Evil Lurker
              Warranty Voider
              • Feb 2011
              • 454
              Get some Chip Quik. Its a special solder that stays liquid for like 30 seconds... plenty long enough to get the IC loose. For resoldering you can practice your drag technique, but for me I would go the hot air route with some mechanics soldering paste.
              • bbjunkie
                • Dec 2011
                • 301
                Thanks for the replies. Think i'll go the hot air route as no doubt i'll be faced with this again in the future.
                Any recommendations on a reasonably priced station for occasional use? (preferably not Chinese)
                • thesloc
                  Banned
                  • Dec 2011
                  • 587
                  http://www.youtube.com/watch?v=5uiroWBkdFY
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • Glaval
                    Sony OLED XBR-65A8G 4 flashes
                    by Glaval
                    Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                    01-23-2025, 04:04 PM
                  • Geeker007
                    Friend messed up my laptop motherboard while working on my bench
                    by Geeker007
                    Hi All,
                    So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                    So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                    I have not tried putting...
                    06-16-2025, 01:40 PM
                    Multifix 425-01 and 450-01 Rework Flux Datasheet
                    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                    - No Clean Formulations
                    - Low residue
                    - Range of activity to deal with different component solderability
                    - Halide free
                    - Suitable for dispensing
                    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                    Both products are supplied in syringes or cartridges for application by dispensing....
                    10-07-2024, 06:02 AM
                  • petemanuk
                    BGA solder balls not connecting - help pls
                    by petemanuk
                    So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                    I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                    I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                    11-16-2022, 05:21 AM
