Hey guys, i'm looking for a cheap multi meter and i found like 2of them. One is a velleman dvm810 and the other is a a&d weighing ad-5526 multimeter. Now i think dvm810 is pretty good for 10 bucks. I probably won't use it that much. What do you guys recommend for a cheap value? Thanks for replies.
need cheap multimeter...
Re: need cheap multimeter...
Do you need it right away? If not, you can get some really good deals on ebay on non Fluke brands.
Recently, I lost on 2 separate ebay bids for name brand (not Fluke) True RMS multimeters. Both are around $100 new. The winning bids were $7.05 and $6.55 respectively.
Either one of the above is much better than the $10 options.
Look for names like Ideal, UEI, Greenlee, Amprobe, Meterman, Extech, and BK Precision. I managed to get a good Amprobe 15XP for 99 cents on ebay.
PS. I like Fluke multimeters and I have 2 of them, but they always sell for a premium (even used) and in some cases they are justified. Both my Flukes are used. I got the Fluke 75 for $20 and Fluke 12 for $30.Last edited by retiredcaps; 01-03-2012, 05:17 PM.--- begin sig file ---
--- end sig file ---
by aaronkatriniHi all,
- Autorange
- DC volts up to 30V
- Accurate Resistance
- Diode test (Beep mode)
- Frequency up to 200MHz
- Capacitanze up to 5000uF
- as cheap as possible
Other functions are not needed but those which are needed... -
by smaliHi
My Fluke 189DMM rotary contacts are missing. Can anyone tell me where to find them or any other way to make it?... -
by Pauldg1I have a Fluke 289 multimeter which does not work.
Have anyone an idea what could be the cause?
When I turn on the device only the green led is continuously on, and strange stripes are present in lcd screen. I can only turn off the device by removing the batteries.
Any suggestions will be appreciated... -
by dj8452000I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
by yayayeeHello,
I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...2 Photos - Loading...
