my boss. we had 3 computers (slightly over a year old), 2 HP, one Asus. All bad caps. One has wavy lines over the vga onboard output (4 bloats next to the northbridge), one just won't boot, no wait the other one just won't boot too. I offered to replace the caps for $50 each, naw, we'll just get new motherboards from frys, and charge them $150+. better profit margin
"screw that, we can make more getting new motherboards"
^If you have datasheets not listed PM meTags: None -
Re: "screw that, we can make more getting new motherboards"
Now get him to give you the bad boards.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. -
already been arrangedCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
Securing a good thermal interface between...-
Channel: Common Parts Library - Datasheets
10-07-2024, 04:35 AM -
by ProttHello dear Badcappers,
I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...2 Photos07-27-2024, 08:54 AM -
by qwerty99Hello!
I need to change the capacitors on my three original Xboxes.
Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t... -
by zman78Hi All,
I have an LED Light array that had a built-in AC-DC 24v 45 watt power supply. The power supply failed so I desoldered the LED Light array power input wires from the power supply and then screwed it into barrel connector jack (ends still tinned with the original solder).
This is the barrel connect or jack https://www.amazon.com/gp/product/B07Q6YMM6F/
Then I bought an external 24Volt/3Amp power brick (with same size barrel connector output) and plugged it in.
Everything works fine, except that the screw-in barrel connector gets... -
by Fast AlphaEVGA 750ti SC graphics card stripped screw. I need this screw to attach the fan and heatsink to the card here are pictures to show you what I mean.
The one screw on the back at the corner only.
Do you know the size of screw needed.
- Loading...
