Since I Did Not Get an Answer I'll Ask Again + Some
  • killian6pk
    • Apr 2010
    • 502
    My first question was with the very small caps like 0.1uf to say 2.2uf. Do these also need to be Low ESR for Monitor Power Boards etc?
    Second Question: What are you looking for on a Data Sheet to identify Low ESR? Is it ripple current or impedance? And what type of datasheet info constitutes one or the other (range)? I have been checking my caps to try to identify the low esr that i might already have. Some say Standard or General Purpose, but them some don't say either of those two things. Just trying to get some education.
    Third Question: Are Audio grade caps usually Low ESR caps or is that to broad to say that?
    Fourth Question: The large filter caps. Do they need to be Low ESR or are you concerned with something else with them (100uf/450v.)? Also on Panasonic or Nichicon what series would you use?
    See you should have answered my First Question.
    Thanks For The Help. I have several monitors that I am trying to repair with the expertise of everyone here. I am learning a lot from reading the posts.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Since I Did Not Get an Answer I'll Ask Again + Some
    1. Don't know
    2. inpedence
    3. sometimes, depending on what kind of audio device
    4. power supplies aren't necessarily low ESR, infact there has been some recap attempts with lower ESR caps and they have caused stability issues. Going down in ESR is usually better for computer-based VRM's
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      1.
      They need to meet or exceed the original specs.
      If the originals are low ESR, then yes.
      Originals that small are rarely low ESR in the app you specified [but could be] so you just have to check.
      If not low ESR then choose the new caps by the Ripple rating.
      2.
      For most. - Impedance at 100kHz and 20°C - in Ohms.
      [100kHz is close to the ripple frequency from an SMPS or a VRM.]
      For caps intended for just after the first rectifier - Impedance at 100 or 120 Hz and 20°C - in Ohms.
      [100 and 120 Hz are 2x line frequency depending on where you live. That's the frequency you get after the rectifier.]
      Terms like "Standard", "Low ESR", "Ultra Low" have no official *standardized* meanings [no 'official' definition] so manufacturers can call their caps whatever they want.
      Brand A's "Super Duper Ultra Extra Low ESR" cap series might be exactly equivalent to brand B's "Sort'a Low ESR" cap series.
      - The terms are essentially meaningless.
      - Ignore the terms and look at the specs.
      3.
      Sometimes.
      "Audio Capacitor" also has no official *standardized* meaning so manufacturers can their caps whatever they want in regards to that. Some of the reasons they use to tag their caps with that name are pretty lame. [AKA: Complete BS.]
      4.
      Presumably you mean the caps that are huge relative to the other caps.
      Those filter [smooth] the input rectifier.
      Originals for just after the rectifier sometimes are and sometimes aren't low ESR.
      Designs vary A LOT. - There is no magic pill that -always- works.
      If you want the proper caps you have to find out what the old ones are.
      Mann-Made Global Warming.
      - Dr Seuss
      • killian6pk
        • Apr 2010
        • 502
        Thanks guys I'm still learning. You've been a big help.
          by momaka
          03-12-2025, 03:42 PM
          by momaka
          03-15-2023, 10:17 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
