Motherboard VRM output current limitation
  • ssb2245
    Now I understand that the limit part for current output on a motherboard is partially to do with the pins from teh PSU 12v connectiona nd teh pins in the socket.
    But I want to talka bout the buck converter, the main VRM for the CPU power.
    I know MOSFETs on boards are rated from 20-50amps. My question is about the inductors(chokes) and how they limit current. i understand that they have 2 current ratings,
    Irms which is continuous current, and Isat which is saturation current. I know that once you exceed saturation current the inductor's core becomes flooded with magnetic flux and it loses inductance. Does the Isat and Irms limit the amount of current a MOSFET can output to the capacitor bank and then to the processor.
    Lets say the inductor in question has an Isat of 28a and Irma of 28A and the MOSFETs can otuput 40A per phase. Would this mean that each phase is limited to 28A?
    MT3608 Step-Up Converter IC Datasheet
    The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
    Internal soft-start results in small inrush current and extends battery life.
    The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
    10-07-2024, 05:02 AM
    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
    Narrow VDC applications where the system power source is
    either the battery pack or the regulated output of the charger.
    This makes the max voltage to the system equal to the max
    battery voltage instead of the max adapter voltage. Operating
    at lower system voltage can improve...
    11-05-2024, 04:43 PM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
    The bq24745 features dynamic power management...
    10-23-2024, 02:50 AM
  • caspian
    How much output current is required on the Laptop rails?
    by caspian
    Dear Technicians,
    Lets consider the buck converter circuits that we see in Laptop mainboards including 3.3v, 5v, 1.05v, RAM power rail, CPU_Core rail, and GPU_Core rail. The schematics mention that such a buck converter circuit can provide the maximum output current such as 9A, 14A, or 16A.
    What are the typical current and the maximum current that you observed in practice separately on these rails including 3.3v, 5v, 1.05v, RAM power rail, CPU_Core rail, and GPU_Core rail?
    I mean, how much output current is required on these rails in practice?
    Note: I do not...
    11-30-2021, 06:05 AM
