Capacitor tester how usefull is such a tool?
  • nico-e
    • Sep 2010
    • 20
    ive heard of capacitor testers named ESR-Meter how useful are such testers.
    For example i have an MSI KT4AV-L Mainboard(with Rubycon, Chemicon caps and one teapo) which stopped working, so I want to test them before recapping this board.
    thanks
    nico
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Capacitor tester how usefull is such a tool?
    ESR meters cost between $65 and $300. Unless you do this for a living, "blind" recapping everything is usually cheaper.
    Most people here like Rubycon and United Chemi-con caps as per
    https://www.badcaps.net/forum/showthread.php?t=2280
    However, United Chemi-con KZG are a problematic series.
    PS. There are some build your own ESR meters. This topic has been discussed before and you can search for it.
    --- begin sig file ---
    --- end sig file ---
    • nico-e
      • Sep 2010
      • 20
      as I have arround 10 boards and several PSU's with cap problems and not all are worth recapping them completely(I recap just for fun), I will buy one of those testers.
      thanks
      nico
      • Agent24
        I see dead caps
        • Oct 2007
        • 5008
        • New Zealand
        I built one of the Blue ESR meters. I like it very much, and it was fun to build too!
        It's also a good test of your soldering skill, if you fail to construct the meter you probably shouldn't be recapping (yet) ha ha....
        -David VanHorn
        • nico-e
          • Sep 2010
          • 20
          do you have a link to your model I'll have a look at it.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5008
            • New Zealand
            http://members.ozemail.com.au/~bobpar/esrmeter.htm
            -David VanHorn
            • daimoku
              • Feb 2011
              • 85
              I also built the Blue ESR meter and I've been pleased with it.
              • gerg
                • Nov 2010
                • 278
                I just purchased a ESR-micro 4.0 and couldn't be happier it is very handy to have around in the month that I have had it it has paid for itself. I can't speak for the Blue meter I love the fact that Bob Parker is on this forum if i were to have a problem with it.
                • redwire
                  Making a capacitor discharge tool
                  by redwire
                  I'm making a new capacitor discharge tool. Asking for suggestions for sizing the discharge resistor.
                  Mr. Carlson's Lab High Voltage Capacitor Discharge Tool 1 is using 4 of 1kΩ 50W aluminum (mount to heatsink) resistors in series for 4kΩ 200W, so it's big, which is fine.
                  His Patreon but I don't have a paid subscription for the project details but it looks straightforward. The plastic box with aluminum plate can't get rid of any amount of that heat though.
                  Wirewound resistors can be overloaded by a factor of 5 for 5sec. and a factor of 10 for brief times. I've never tried say...
                  06-18-2023, 07:09 PM
                • rex98
                  HP DMI Tool
                  by rex98
                  HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                  DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                  The DMI Tool given here are for personal use only.
                  DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                  You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                  from it, and that you please credit the author...
                  07-02-2025, 05:51 AM
                • Prolog
                  by Prolog
                  12-01-2024, 08:27 PM
                • chth96
                  by chth96
                  12-22-2023, 04:34 AM
                • salim5566
                  loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                  by salim5566
                  Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                  06-26-2025, 03:25 PM
