old caps
  • cmj21973
    • 267
    old caps
    I have some old game consoles that have been sitting around for 20+ years, that still works, but I am wondering about the caps.
    Should I leave them be, pull them and check them, or just recap them.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: old caps
    let them be... unless they are not working, let them be.
    sigpic
    (Insert witty quote here)
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Re: old caps
      check if they're bulging/bloated or leaking. if not, leave them alone.
      if they do, replace asap
      don't fix what ain't broken
      • cmj21973
        • 267
        Re: old caps
        Ok and thanks for the info.
        I will leave them be. The caps looked fine when I cleaned the contacts in the console and carts.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          Re: old caps
          Are we talking about a SNES old enough to have the removable sound module? There are two small caps in there, that if they leak, the traces will be destroyed.
          -Paul
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • cmj21973
            • 267
            Re: old caps
            I have an Atari 2600, Atari 2600 jr, NES, and SNES.
            I've only checked the NES. Others to be check when I have time. Waiting for for gamebits to check the SNES and game carts.
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              Re: old caps
              Check for leaking lithium backup cells in the SNES carts! As well as LOZ/AOL and any other save carts for the NES...
              -Paul
              EOL it...
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
                by momaka
                03-15-2023, 10:17 PM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
