Haier plasma 42hp25bat wont power on ( its realy an LG)
  • haiertv
    • Jan 2011
    i realy hope that someone can help me figure out whats gone bad.
    I have a Haier 42hp25bat which is LG allover inside. the picture went out but still had sound, i opend the cover and discovered the top fuse next to the 2 caps, blown on the ysus # 6871qyh953a. i replaced the fuse and inspected all the caps which looked all flat and fine. tried to power on and all it does now is click on (no picture) then click off after a few seconds. i dont know which board is gone bad to replace or order. power suply board# 3501q00201 looks good with no visual burns or bulging caps so is the Zsus#6871qzh956a.
    Last edited by haiertv; 02-02-2011, 12:47 PM. Reason: change from general electronics to tv trouble shoot
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Haier plasma 42hp25bat wont power on ( its realy an LG)
    I dont know much about plasma's but if a fuse blew, something made it blow. I'd start on that board to try to find my problem.
    Recheck that same fuse. It may have blown again.
    Post a clear picture of that board.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • beetle1303
      Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
      by beetle1303
      I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
      On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
      01-13-2025, 08:49 PM
      03-31-2024, 02:12 PM
