Testing a Zener-Protected SuperMESH MOSFET With A Multimeter
  • stevekasian
    Old N00b
    • Dec 2010
    • 182
    • USA - West Side!
    I am trying to obtain a rough determination as to whether a component is burned out or not. It is a 10NK70ZFP Zener-Protected SuperMESH MOSFET and can be found here: https://cdn.badcaps-static.com/pdfs/...846f9f6885.pdf
    Can anyone give me any advice on what kind of readings I should get if the part is working properly?
    Thanks!
    Steve
  • stevekasian
    Old N00b
    • Dec 2010
    • 182
    • USA - West Side!
    Re: Testing a Zener-Protected SuperMESH MOSFET With A Multimeter
    I've removed the component from the circuit and checked it on the 20 ohm scale.
    G-D and D-G measure about .4 ohms. This is not a good thing I presume?
    • stevekasian
      Old N00b
      • Dec 2010
      • 182
      • USA - West Side!
      SORRY - MISTAKE:
      The measurements above should be S-D and D-S measure about .4 ohms, even after I short the source & gate together to discharge it.
      Is this a bad thing?
      • PlainBill
        • Feb 2009
        • 7034
        Originally posted by stevekasian
        SORRY - MISTAKE:
        Good / bad is an ambiguous concept. For example, your doctor tells you your chest pains are due to a 90% blockage of two of the arteries in your heart. They can easily insert stents. You'll be out of the hospital the next day, normal activities in a week. Is this good news or bad news?
        Similarly, yes, the MOSFET is bad. On the other hand, you can easily replace it rather than spend hours trying to locate a failed component.
        PlainBill
        • stevekasian
          Old N00b
          • Dec 2010
          • 182
          • USA - West Side!
          Thanks PlainBill. Much appreciated wisdom.
          Correct me if I'm wrong, but isn't it a good thing to know whether a high power component, such as a particular MOSFET, is bad in order to help realize what other potential problems may exist with the circuit?
          Thanks,
          SK
          • Agent24
            I see dead caps
            • Oct 2007
            • 5085
            • New Zealand
            I think the more you know about it the better, whether or not you actually find out is a different matter...
            -David VanHorn
            • meokito
              • Mar 2011
              SORRY - MISTAKE:
              Hi, and finally... it was good or bad? I have the same doubt
              Regards
              • dj8452000
                How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                by dj8452000
                I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                02-18-2025, 08:28 AM
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
              • Nooy
                VGA MOSfet permanently shorted and loss of MOSfet pad
                by Nooy
                Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                02-14-2024, 02:26 AM
              • Kosala Balasooriya
                What is the best multimeter can be used to check laptop mother bord testing
                by Kosala Balasooriya
                I am a new student.I am looking for repairing tools..What is the best multimeter testing mother bord
                02-28-2023, 10:27 AM
              • redbaron1007
                Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                by redbaron1007
                I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                09-09-2025, 11:10 AM
