General question : Repairing graphic cards
  • newbie1
    • Apr 2010
    • 269
    Hi Guys,
    just wondering whether anybody here ever repair graphic cards with no visible capacitor defect?
    I have a bunch of AGP & PCIE graphic cards confirmed faulty by replacing them with a known good one. They have symptoms like :
    - No display but fan spinning
    - Display but fan not spinning.
    - No boot-up at all.
    - Boot up but display is having snowy lines.
    - Display flickering (shutting down & re-start) - not monitor problem.
    Or do you guys think they are not economically not worth it & BIN them?
    thanks for your input, guys..
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: General question : Repairing graphic cards
    Fixing them sounds nice. AFAIK, bad capacitors, stuck fans, and faulty solder are the three main problems.
    - No display but fan spinning (reflow)
    - Display but fan not spinning. (new fan)
    - No boot-up at all. (no clue)
    - Boot up but display is having snowy lines. (try underclocking/undervolting)
    - Display flickering (shutting down & re-start) - not monitor problem. (no clue)
    • newbie1
      • Apr 2010
      • 269
      Yes if i can only fix them, then it would be REALLY awesome.. Having a self-made scrapyard full of ATI & NVDIA GPUs, is definitely not.. heh!.. I guess the low cost of it wouldn't be cost effective & time wasting to repair them.. & so far i have not seen a schematics for it as well.. yet.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        I would start with the easiest cases, for example the cards that work normally, but the cooler fan is stuck.
        Then I would proceed to the gpus with bad caps etc.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5008
          • New Zealand
          I have heard that the BGA RAM or GPU can have soldering issues.
          You can reheat with hot air or in oven... but I think what you really need to do is remove the chip and do a full re-balling and reflow.
          Either way, you have nothing to lose if the cards don't work now. The worst that can happen is they still don't work afterwards.
          -David VanHorn
          • crepiduse
            • Nov 2010
            • 69
            I have repaired some ATI and NVIDIA cards with no clean flux and hot air, just make sure you have proper cooling to the chipset after. 9/10 with bad connections (snowy picture or no picture with good caps) are fixable this way.... How long it will work, is unknown, I have one I fixed a year ago still working fine, if done right it should last just as well as a reflow. Flux it, heat the board, then slowly heat the chip, then slowly lower temp back to cool, then let sit for cool down and wha-la, working board. Same repair as XBOX360's or DV series laptops.
