Read eMMC chip using SD card reader
  • vbogoev
    • Nov 2021
    • 15
    • Bulgaria
    I found several sources where guys successfully read eMMC chip using a SD card reader. I was interested to try it, just to practice micro soldering, but for some reason I am unable to read the chip. The chip is known working one (desoldered from an old working device) model Samsung KLM8G1WE4A-A001. The card reader is Transcend USB 3.0. So basically I've connected everything as it is described in the schematic, but the sd card reader didn't even start to blink. I am not sure what I am missing, so I'll appreciate some help...
  • harp
    • Jun 2022
    • 645
    • Planet Earth
    Re: Read eMMC chip using SD card reader
    So, have you check power voltage on sd and mmc?
    From pictures, I can not trace anything...
    When you working on such delicate things, sometimes is best to disconect and clean everything, and start all again from null rather then to troubleshooting. Be careful about orientation and view point on schematics, and maintain fully concentrate and piece while doing that. Use a ribbon cable from ide drive or so if is handy to minimise mess.
      • 31265
      first, as your soldering to a socket, did you deal with the switch that tells the interface you have a card plugged in?
      second, how are you reading it? you probably need to do a block-dump, if you expect windows to show you a bunch of files your probably going to be dissapointed.
      • vbogoev
        • Nov 2021
        • 15
        • Bulgaria
        Thanks for the advices. I started 3 times from the beginning, but at the end I am pretty sure everything is connected as described. I am not sure if RSTN should be pulled up in order to enable the chip, but from the datasheet it seems like this is how it is supposed to work.
        Indeed, at first I didn't know for the card detect switch, but then I plugged another card in the socket, wrapped with capton tape on the pins and now card detect pin on the chip is ON.
        However, there's no voltage passed to the chip, between 4 and 6 pins there are 0 volts. If I test with normal SD Card there are 3.3V.
        What I am expecting to see is first to have 3.3V on the power rails and then the reader flash to indicate something's going on. After that I'll think about the data extract, but yeah, I expected to see a bunch of files, like I was inserted normal sd card.
        So I am missing something, but not sure what...
          • 31265
          well i'v never seen an 8bit emmc, sdcards are only 4bit i think.
          that doesnt explain why the 3.3v isnt coming on - you would expect that just with the detect switch even if there was no card/chip
          • vbogoev
            • Nov 2021
            • 15
            • Bulgaria
            OK, found the problem. It was me of course...
            The schematic show the chip pinout when it's upside up, I interpreted it as upside down as the pinout is symmetric.
            Anyway, I successfully read the IC but it was not possible to open the userdata volume using Linux Reder program. Not sure it the content is encrypted. However, I successfully opened the system volume.
              • 31265
              if you dumped it as a big block of data, you may be able to identify the filesystem and mount it
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • BMCappelletti
                Asus Chromebox CN62 - wrong chip put on BIOS reader
                by BMCappelletti
                Long story short:
                - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                - gave the computer to his son a couple years later
                - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                (seems like the story was not that short)
                He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                01-08-2025, 07:27 PM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                08-04-2025, 12:20 PM
              • GMAN-2022
                BGA153 eMMC Chip Writer Needed
                by GMAN-2022
                I have a home automation controller (Control4) where the eMMC chip where some sectors on the chip is corrupted. The controller runs a linux based system. I believe the bootloader/kernel is bzImage.
                The model of the eMMC is SanDisk SDIN8DE2-8G.
                My objective is to purchase a new SanDisk eMMC chip and flash a working image on the eMMC chip before I take the circuit board to the local electronic shop to remove the old chip and install the new chip. I have confirmed with the local electronic shop that they are able to remove and install the new eMMC...
                03-23-2021, 06:25 PM
                by SMDFlea
                Bad...
                09-02-2021, 04:40 PM
