Suitable replacement IC? .PCB - X_BFJSFANRE_RLED_V4
  • ezenia
    • Jun 2020
    • 58
    • England
    I am not sure where exactly to put this thread, so hopefully this is the best place.
    I have a USB fan that has suddenly been unable to increase its speed. It's just stuck on the first speed. This fan has 3 speed settings. Each time you press the power button, the speed of the fan should increase.
    The way the button works with each press is: Speed 1 > Speed 2 > Speed 3 > OFF
    Speed 2 and 3 don't currently work any more.
    I suspect the issue might be with what looks to be some kind of driver IC. It is a 16-pin and the fan power switch goes to this IC. The IC has no markings, so I can't find the exact part.
    Does anyone know of a suitable IC replacement that can be bought? I've attached an image of what the IC looks like. If anyone has any advice on how I can check if this IC is definitely the problem, that'll be helpful as well.
    • 31269
    Re: Suitable replacement IC?
    does the button still turn the fan on and off?
      • Jul 2011
      • 6070
      What is the marking on the ic chip
      • redwire
        • 3912
        Weird how the IC has a bunch of pins not soldered and sitting on top of silkscreen. Also, the 4R7 seems low for any pin on a SOIC-16.
        Can you show us pics of the whole board.
        • ezenia
          • Jun 2020
          • 58
          • England
          Yup. The button still performs those functions as normal. It just no longer increases the fan speed when I continue to press the fan button.
          What should happen is I press the button and the fan comes on (speed 1). If I wanted to increase its speed, I press the button again. This should cause the fan to speed up (speed 2). If I press it again, the fan will enter speed 3 (highest speed). If I press the button one last time, the fan turns off (as it should).
          Right now when I try to initiate speed 2 and 3, the fan does not speed up. The final press still turns off the fan as normal.
          @sam,
          There doesn't seem to be any markings on the IC. It's blank.
          @red,
          I've attached a pic of the whole PCB. The other switch on the PCB is for another function I haven't used. It's for some "water mist spray"
          https://flyingtiger.com/en-gb/produc...-light-3048154
          That's a link to what the fan actually looks like.
          • ezenia
            • Jun 2020
            • 58
            • England
            Could the USB IC be responsible for the speed control issues? There is a 6-legged IC near the USB port. There's also some LEDs nearby. One is green and another is red. The green LED looks to be for when everything is OK and working. I've seen the green LED shining when I used the fan before.
            When the fan is plugged into a power source and the fan is off (not spinning), I notice the red LED is faintly flickering red. I don't know if this is normal behaviour. When I turn the fan on, the red LED goes solid red. The green LED is still on as well.
            The markings on the USB IC look to be "LPS BMCH1". I could not find anything about this from a Google search.
            I did find this https://www.mouser.co.uk/ProductDeta...ym3GprBA%3D%3D which looks like it could be an IC like this. On the datasheet, it mentions a FAULT pin. Could the IC be detecting a fault of some kind and that's causing issues with the speed control?
            • peter_
              • Jun 2023
              Which connector is going to the fan ?
              The IC near the USB port will be a voltage regulator. The black IC will be a cheap microcontroller. The fan speed will be controlled by a PWM signal. If you have a scope you can monitor the driving signal to one of the small transistors.
              • ezenia
                • Jun 2020
                • 58
                • England
                Re: Suitable replacement IC? .PCB - X_BFJSFANRE_RLED_V4
                The middle connector is the one for the fan. I don't have a scope unfortunately.
                I did check the pins on that microcontroller IC and the upper pin on the left side of the IC has voltage that changes with the button presses.
                On the first press (speed 1), the pin reads 1V. The 2nd press (speed 2) reads 1.4V and the 3rd (speed 3) reads 1.8V. I don't know if these values are good/normal, but this does tell me that something is happening. I followed the voltage to Q2. It's on the left pin. The lone pin at the top has 4.74V.
                The voltage at the fan button is around 4.14V. This does not change. If I hold the button down, it reads 0V, but otherwise it just stays at around 4.1V.
                Another thing I find odd is the behaviour of the red LED (It's the top one in the LED1/LED5 area). It's flickering red when the cable is connected, with the fan switched off. When I measure the voltage on the fan button, the red LED goes solid red. It also goes solid red when I turn the fan on normally.
                I don't know what the supposed function of the red LED is, but I can only assume it's not for anything good. There's already an LED for power (it's green), so the red must come on when something is wrong.
                  • 31269
                  check all transistors, diodes and caps for shorts.
                  the chip obviously works,
                  it's probably using one transistor to vary the voltage to the motor and another to just turn it on and off.
                  the part with 5 or 6 pins is the usb charging chip,
                  too bad about those missing resistors R2 and R4, i suspect they are to activate intelligent usb powersupplies.
                    • 31269
                    btw, the picture is not clear enough to read the markings on the transistors,
                    but those inductors make me wonder if atleast one of those "transistors" is actually some type of voltage regulator.
                    • ezenia
                      • Jun 2020
                      • 58
                      • England
                      I've attached another pic of the PCB. Hopefully you can see the markings on the board more clearly. If not, I'll try to take another.
                      • ezenia
                        • Jun 2020
                        • 58
                        • England
                        I checked for shorts, but couldn't identify any.
                        • ezenia
                          • Jun 2020
                          • 58
                          • England
                          Do these voltages at U1 look normal?
                          This is with the cable plugged in and the fan being off:
                          Pin 1: 3.3V
                          Pin 2: GND
                          Pin 3: Around 4.2V
                          Pin 4: 4.74V
                          Pin 5: Can't get a stable reading, it's jumping between 015.0-070.0mV
                          Pin 6: 0V
                          With the fan turned on (first speed setting):
                          Pin 1: 0.670V
                          Pin 2: GND
                          Pin 3: 4.08V
                          Pin 4: 4.73V
                          Pin 5: 2.178V
                          Pin 6: 020.7mV
                          The pin values don't really change with the other speed settings.
                            • 31269
                            so pin9 is speed control.
                            and pin1 is the on/off
                            what are all the connectors for?
                            i see 3 of them!
                            • ezenia
                              • Jun 2020
                              • 58
                              • England
                              The other connectors are for the water mist spray feature. I don't use that part of the fan. I've only ever used the fan itself which is the middle connector.
                              I am pretty sure the fan feels quieter as well. I remember this fan being quite noisy even on the first speed setting. Now it seems like it's quieter, perhaps it's running slower than normal.
                              I currently suspect something might be wrong with U1. The behaviour of the red LED is bothering me as well. I don't think it should come on when the fan spins, or be faintly flickering rapidly when the cable is plugged and the fan is off.
                              It makes no sense to have two LEDs for just power. The green one is meant to be on as I've seen it through the port when I used the fan. The red one though? I don't know if it's meant to be on or not.
                                • 31269
                                red is probably low-battery and/or used by the charger
                                • ezenia
                                  • Jun 2020
                                  • 58
                                  • England
                                  This fan isn't using a battery. One of the connectors is unused. I remember one of them was empty. I checked with the Google translate app and it says the connector near D1 is "Battery". I wouldn't think they'd add a charging circuit to a board that is not making use of the battery connector.
                                    • 31269
                                    the 6pin thing is a TP4057 charging chip
                                    • ezenia
                                      • Jun 2020
                                      • 58
                                      • England
                                      Ah yes, looks like it is. The voltage at pin 3 (labelled BAT on datasheet) is present on the battery connector.
                                      Any idea what the STDBY pin is meant for? When the USB cable is plugged into the port and the fan is off, I am not getting a stable voltage reading on this pin. Once I turn the fan on, the voltage on this pin goes to 2.2V. Is this normal behaviour?
                                      Should the battery voltage also be present at the fan switch button? Since this fan doesn't use a battery, shouldn't the voltage here match the VCC pin (which is around 4.74V)?
                                      • ezenia
                                        • Jun 2020
                                        • 58
                                        • England
                                        Another thing:
                                        With the USB cable plugged in and the fan off, if I try to measure voltage on U2 on either pins that lead to the button switches, the red LED goes solid red and the voltage does drop slightly.
                                        If I measure the battery voltage in another area (say at the battery connector or R7), I get a reading of 4.2V (it's not steady though, it keeps going from 4.2v to nearly 4.3V and then down again).
                                        Once I try to measure the voltage at the aforementioned U2 pins, the voltage drops ever so slightly and is very stable (sits at a steady 4.14V). The fan isn't on though since the LED that tells me that remains off (it's next to the switch itself).
                                        The battery voltage with the fan properly on drops to a steady 4.05V.
                                        These readings aren't making sense to me. Something seems to be wrong somewhere. It explains why the fan is not speeding up and why it seems to be running slower than normal (evident by how much quieter the fan is).
                                        • r2digital
                                          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                                          by r2digital
                                          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                                          04-18-2024, 03:50 PM
                                        • Woodsworth
                                          PS3 CECHC03 60GB YLOD Troubleshooting
                                          by Woodsworth
                                          I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                          START
                                          Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                          03-19-2024, 07:58 AM
                                        • Benass
                                          Looking for Suitable Relay Replacement.
                                          by Benass
                                          Hello. I have Industrial Washing Machine PCB.
                                          Customer Requested Relays Replacement.
                                          I can't find WJ115F1 relays to buy. Looking for some help to identify possible alternative solutions.
                                          Or any tips, on how to approach this situation....
                                          04-21-2023, 01:51 PM
                                        • fytonv
                                          7 channel NAD receiver,Need help identifying a suitable cap replacement
                                          by fytonv
                                          My 7 channel NAD receiver has audio quality and volume issues on 2 of the channels. Sometimes they work and sometimes they don't. Sometimes they're at about half the dB level of the left channels, and then they cut out entirely. Powering off and on the receiver fixes it for a bit.
                                          Without much experience to really know for certain, they only apparent issue I can see is with these electrolytic capacitors on the power supply. Bulging = bad, correct? I'm looking for replacements but I'm unsure what leeway I have with the temp ratings. Are there any other specifications I need to worry...
                                          09-08-2022, 09:52 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
