Mosfet Replacement MTP 2955V
  • billy66
    • Mar 2010
    • 124
    Hello. I'm trying to find a replacement for a Mosfet I have labeled:
    NL243
    MTP
    2955V
    It seems this one is no longer made. I've found some on ebay, but with shipping and "handling" it comes to over $7... which seems a little high.
    Can someone help me cross reference one that will work? It is for a Samsung SyncMaster 151s Monitor.
  • Quasar
    • Sep 2010
    • 132
    Re: Mosfet Replacement MTP 2955V
    MTP2955V/VG - New number from Onsemi.com NTP2955-D.
    Datasheet:
    http://www.mouser.com/ProductDetail/...yPfRNz9C6JY%3D
    http://parts.digikey.com/1/parts/111...b-ntp2955.html
    Learning how to dig for numbers gets easier as you go.
    • billy66
      • Mar 2010
      • 124
      Thanks!
      • DoOm86
        Dual mosfet replacement help
        by DoOm86
        Hello.
        I have a notebook with a shorted mosfet, it's a E6930 GA8125.
        It seems to be a 30V dual asymmetric N-channel AlphaMos.
        Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
        And here is where I need help!
        It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
        I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
        Thanks!...
        10-31-2023, 12:03 PM
      • jm942
        Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
        by jm942
        My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
        I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
        I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
        I did voltage injection on the cpu with 0.7V and i have a current...
        07-11-2024, 05:11 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • String2016
        SMD MOSFET REPLACEMENT
        by String2016
        Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
        01-23-2025, 06:35 PM
      • String2016
        by String2016
        i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
        12-15-2024, 05:31 AM
