93C46 and 93C56 EEPROM
  • SidneyCanadas
    • Jun 2023
    • 5
    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old EEPROM and program the new EEPROM from a Camry # 93C56 which I will purchase from Digi-Key?. Again both of these EEPROMs are surface mounted devices, not through hole. I am an electronics engineering technician by trade and have no problem soldering out the chip and soldering in a new one but software was always my weakness.
    For those of your not familiar with I am doing, for the North America market ALL:
    2003-2008 Toyota Corolla
    2003-2008 Toyota Matrix
    2003-2008 Pontiac Vibe
    2004-2005 Toyota Prius
    when the odometer reaches 299 999 KM or miles it stops, and will not roll over to 300 000 KM or miles but if you read the EEPROM it continues to count true mileage but display only shows 299 999. Summary: I would like to know if I purchase from Digi-key a 93C56 EEPROM to replace my Corolla 93C46 EEPROM if the odometer will roll to 300 000 KM or miles and continue to count. Also which EEPROM reader/programmer do you all recommend that allows to interface with a surface mounted device (not through hole).
    Thank you in advance for help/replies.
    Sidney
    Dartmouth, Nova Scotia
    Canada
    • 31014
    Re: 93C46 and 93C56 EEPROM
    changing the eeprom will not work,
    the lack of rollover is down to the software in the dash or ecu
    it's possible there are configuration bytes in the eeprom that could help, but you would need to ask on a toyota hacking forum.
    • SidneyCanadas
      • Jun 2023
      • 5
      There is a micro in the instrument cluster, this guy is confusing but it might help you to help me:
      https://socalspeedometer.com/speedom...m-or-miles-why
        • 31014
        no, he said what i said - it's a software issue.
        and looking at that picture, the miles/kilometers are encoded in some bullshit way to make it hard to change the readings.
        thats a seperate issue btw and easily fixed by just restoring an earlier backup
          • Jul 2011
          • 6039
          This limitation was introduced because of to many people were rolling back mileage so they were forced to make very difficult to modify the odometer
          The only thing I could think might help you is to replace it with an odometer that has very low mileage and just make a note of the mileage when you did this so you keep track of how many miles are on this vehicle
          I have a truck that the odometer stopped working because of a stripped gear shaft I just found one in the junk yard that was not stripped and it been working for last few years now ( this was very difficult to do because you had to be careful not to strip the replacement parts or you would have to find another one that was not stripped )
            • 31014
            personally i think the whole idea of the odometer is bs,
            it does not tell you the condition of the drivetrain - thats down to how it was driven and serviced.
            look at ex-police stuff to see what i mean, they are usually very low mileage but beaten to hell!
            Porsche has the right idea, the newer cars track the engine runtime in hours - same as you would with an aircraft.
            • SidneyCanadas
              • Jun 2023
              • 5
              But why do all other Toyota vehicles do not have that limitation?.
                • Jul 2011
                • 6039
                The difference might be is if the odometer is digital instead of mechanical type of odometer that is shown as digital would be my guess
                • SidneyCanadas
                  • Jun 2023
                  • 5
                  What? they are all now digital.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    There's a reason why runtime hours is used in aircraft, namely you can't tell distance traveled while in the air... so best proxy is hours. Then it could be said hours running shows nothing about the airframe stress quality, whether the airplane has been traveling through high winds, etc.
                    For cars, odometers do have a direct proxy over some parts, like transmissions and especially tires. They have a correlated but not direct effect to brake pads and of course engines.
                    YMMV. Of course.
                    As an aside, odometers for electric cars is quite possibly a sham in this respect too, though it is still a weak proxy. Almost seems that quantity of full/partial/SOC-relative charge/discharge cycles should be the main metric to battery quality -- which is probably the number one wear item in electric cars.
                      • 31014
                      odometer is often a legal requirement because of government documents that insist on it being noted.
                      anual inspection and ownership documents for example.
                      but with electric obviously the numbers arent worth shit and the real issue is going to be the battery charge-cycles.
                      • dmccul2698
                        Pioneer DEX-P99rs "No EEProm " diagnostic code.
                        by dmccul2698
                        Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                        1). Understand the schematic and check the connections between the EEProm and DSP
                        2). Check the functionality of the EEProm
                        I don't know if this is the unit's problem but it's a place to start.
                        I have little to no electronic experience...
                        04-08-2024, 05:32 PM
                      • edgarmg15
                        Damaged EEPROM on TV Vizio E320-A0
                        by edgarmg15
                        Hi everyone
                        I´m trying to repair a TV Vizio E320-A0 that I found in the street
                        The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                        The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                        So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                        11-19-2022, 03:46 PM
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
                      • AlexGsmMaster
                        Eizo CS2740 eeprom dump, search.
                        by AlexGsmMaster
                        Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                        07-26-2025, 03:24 PM
                      • 247it
                        ThinkPad E15 G4 PD Controller TPS65994AE EEPROM
                        by 247it
                        Hi, I have a ThinkPad E15 G4 I am working on for fun, the PD chip is not talking to the charger, it's stuck at 5v, I have replaced the PD chip three times now (new chips) and always the same result, I have checked for shorts, correct voltages on the PD IC etc - 5v 3v, and the 1.6v on the cc lines, even replaced the USB C port protector IC and the charging port,
                        The PD IC has a EEPROM connected directly, it's the one in the image attached, I assume the PD chip will not start without some initial commands stored in the EEPROM, the PD IC never shows in device manager, i backed up the
                        03-23-2025, 03:53 AM
