How is it possible to destroy someone's computer remotely? How can this be?
  • survivalbloke
    • Aug 2021
    • 304
    I thought this stuff was only in the movies. I have a customer who just dropped off a Legion laptop. He said he was scammed and had a guy remote into his computer to extort him. When he told the scammer he knew what was going on, the scammer got angry and was yelling at him and his computer started smoking!!!! Sounds like bullshit right? Wrong.
    There was a bypass cap as part of GPU vcore and it was EXPLODED. It exploded so hard it ripped the entire trace with multiple vias partially off the board. On the opposite side of the board, a small inductor was also exploded and ripped the board. How is this possible?
    • Jul 2011
    • 6065
    Re: How is it possible to destroy someone's computer remotely? How can this be?
    I want to know how this could possibly happen I have heard of PLC being highjacked but not a laptop computer so how could this be possible that someone could do this
    I even heard malware screwing up your operating system and causing all kinds of havoc but not self destruction only on mission impossible the tv show
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      poor design.
      Even worse if everything is software controlled.
      But it's also possible it was dumb (bad) luck.
      • Bivolalbert
        Help figuring out the resistance of this exploded resistor. gtx 1060 6gb inno3d compact
        by Bivolalbert
        Hello,I need help figuring out the resistance of this exploded resistor. I'm pretty sure it's the one labeled R37. I tried measuring it with a multimeter, but I got different values each time, probably because it's exploded. If you have a schematic, it would be really helpful!
        Its a gtx 1060 6gb inno3d compact, i you have schematic it would be very helpful....
        02-13-2025, 10:30 AM
      • hikomalek
        SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
        by hikomalek
        Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
        When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
        Transformer:
        |Info| Primary | Aux | AB | CD|
        |Ratio|1|25|40|12|
        |Voltage AC|230V|9.2V|5.8V|19V|
        |Voltage DC (*1.41)|230V|13V|8.1V|27V|
        I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
        09-19-2025, 03:30 AM
      • iminusjk
        Lenovo Yoga Pro 9 14IRP8 - help identifying what exploded in the motherboard
        by iminusjk
        I hope this finds you doing well.
        I need some help identifying what and how important is that exploded in my laptop's motherboard.
        Photos attached.
        My laptop is a 1 month old Lenovo Yoga Pro 9 14IRP8 (83BU), i9-13905H, RTX4070, 64 GB ram.
        It was in the charger, and I was excited to play FC24 for the first time, but when the loading screen came something exploded in the laptop and it shut down.
        It didn't turn on for about 30 seconds after that, but then it turned on and has been working seemingly perfectly (at least I didn't notice...
        12-21-2023, 01:30 PM
      • Satdude
        Yamaha RX-479 PSU exploded
        by Satdude
        Hi, I have a Yamaha RX-497 receiver, and one day I came home to a burnt smell and the breaker was tripped. Upon opening the receiver, I saw extreme damage to the main power board. C254 was exploded, R261 was burnt, D255 was shorted, Q254 is open circuit, D261 (bridge rectifier) is also open, traces to IC252 (TC4013BP) are vaporized right off the board. Not sure about any other damage, I'll have to desolder the flip flop to test it. Also the transformer T251 is getting hot when plugged in. What could have caused such extreme damage just sitting plugged in? Only repair that was done in the past...
        04-18-2024, 05:54 PM
      • Crystaleyes
        Indentifying an old exploded cap.
        by Crystaleyes
        Hi all.
        A friend asked me to help remove the mains hum from an old 60's or 70's portable record player.
        The brand is Motoplay, which is an obscure Brazilain brand.
        Anyway. One of the caps seemingly decided to launch itself into outer space and exploded in the process.
        It appears to have been a ceramic disc with coloured stripes, and from the bits I could find and see, it appeared to be either violet or silver on top, followed by some brown, then some orange.
        It definitely had silver, brown orange going down, but the brown...
        08-09-2022, 03:55 PM
