Storing hardware
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Storing hardware
    I have recapped a few boards for some alarm systems. I will most likely not going to use the boards for many years. Question is, should I do anything to keep the lytics in good shape, ie. connect power once a year and leave it running for 24hrs or even more often ?
    Or, can it just be put away and then used in 10 years ?
    On advance, thanks for the help !
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Storing hardware
    keep it away from condensation. if you smoke, keep the smoke away from it (nicotine is BAD for boards). if it has cmos battery, remove it.
    the caps will age either way. if they are good branded caps, then power use should not effect them much.
    sigpic
    (Insert witty quote here)
    • Rob Northen
      • Jan 2010
      • 137
      • Denmark
      Thanks!
      I'am not smoking, so no problem. Boards are stored in apparent, so no moist.
      Its Nichicon PS series, so I guess no pb then
      • Hondaman
        Hardware firewall to block ad servers?
        by Hondaman
        I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
        The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
        02-05-2025, 05:04 AM
      • nobbnobb1
        DIY NAS Service Life (Hardware)
        by nobbnobb1
        So I'm probably a decade behind on this, but my current NAS is a low power machine I built in 2009. It was originally running Windows Home Server, then eventually I migrated to Windows 10 using Storage Spaces for my drive expandability and redundancy. Despite being slow for W10, I love the familiarity and functionality so I never bothered getting into NAS specific OS.
        Hardware wise, it's got 4x drives but the hardware is all super low draw, so the Antec EarthWatts EA380D power supply is barely above ambient. This PSU is apparently known for capacitor issues but when I went in to...
        09-25-2023, 04:35 PM
        Fintek F71868A Super I/O and Hardware Monitor Datasheet
        The F71868A which is the featured IO chip for PC system is equipped with one IEEE 1284
        Parallel Port, two UART Ports, one 80 port (multi with COM2), Hardware Keyboard Controller, and SIR. The F71868A integrates with hardware monitor, 9 sets of voltage sensor, 3 sets of creative auto-controlling fans and 3 temperature sensor pins for the accurate dual current type temperature measurement for CPU thermal diode or external transistors 2N3906. Others, the F71868A supports newest AMD TSI and Intel PECI 3.0 interfaces and INTEL Ibex...
        10-23-2024, 02:26 AM
        Post your Microsoft Automatic bios Update Hardware ID`s
        by SMDFlea
        Some of the newest laptops have the capability to automatically update the bios from Microsoft update.
        If its enabled there will be Hardware ID listed in device manager under
        Firmware - System Firmware - Details - Property - Hardware ID`s - UEFI\RES_
        Example: UEFI\RES_{5E28725C-AA01-4AAA-9E44-414B5EE2EA44}
        Entering the hardware ID {without the curly brackets} at https://www.catalog.update.microsoft.com/Home.aspx
        will show a list of available updates.The downloads are cab files,they can be extracted with winrar or 7-zip.
        Each extracted cab...
        08-04-2022, 12:30 PM
      • ktmmotocross
        Lenovos new Ideapad 3 5G ARM Snapgragon. dont see hardware when installing W11
        by ktmmotocross
        I have this Lenovo Ideapad 3 5G ARM Snapgragon 14Q8X05. that dont see hardware when installing W11. it literally says " install driver to see hardware.
        disc turns bad on him so i dont have recovery
        i cannot find anything about this fault. on support of lenovo same nothing. How to deal with this new lenovo crap?
        07-04-2025, 02:55 AM
