How Do You Test A Metallized 400V 105K Polyester Film Capacitor?
  • 70JUDGE
    • Jul 2010
    • 81
    I have a Trutech PLV16260 LCD TV I have been trying to fix.It is over in the TV forum.I noticed a buzzing noise coming from the power supply.I traced it to a metallized polyester film capacitor marked 400V 105K.Is there any way of testing this?Are they supose to buzz?Thank You very much!
    Tyler
    • 31137
    Re: How Do You Test A Metallized 400V 105K Polyester Film Capacitor?
    they dont buz - post a foto of the top of it.
    • 70JUDGE
      • Jul 2010
      • 81
      Here is what mine looks like.Thank You very much!
      Tyler
      http://cgi.ebay.com/10-Metallized-Po...item335799ac64
      • Krankshaft
        • Jan 2007
        • 2328
        One of the inverter transformers, the main power supply transformer, or an inductor is more likely you need high frequency for something to buzz.
        • 70JUDGE
          • Jul 2010
          • 81
          How can you tell if they are bad?Any way of testing them?I have been trying to fix my TV,but instead of going forward,I'm going backwards.
          I replaced the capacitors that were bad,and the TV was working,then it would only stay on for a few seconds,so I started replacing capacitors that looked good.It seemed like the more capacitors I replaced,the less time the TV would stay on.The last capacitor I replaced,was the main 450V 150UF for the second time,and now the standy light goes out when the power button is pressed,but the TV won't turn on at all.Why I replaced the main capacitor again was bacuase it seemed like the faster I turned the TV back on again after the TV turned off by itself,the longer it would stay on.
          While it was working,I could hear a buzzing noise,and I thought it was coming from the film capacitor.
          I was told that I needed low ESR capacitors in the power supply for it to work right,or at all.That could be the reason why the TV was turning off by itself.Why it won't turn back on after replacing the main 450V 150UF capacitor,I don't know.Bad capacitor?It was the same brand,and series as the first one I replaced,but not the same brand as the original bad one.I checked both replaced new ones on as ESR meter,and they both check alright.Low capacitance?Thank You very much!
          Tyler
            • 31137
            well the foto isnt a safety-rated type.
            the caps you replaced, what type old ones - what type new ones?
            you may have put general use crap inplace of low-impedance parts.
            • 70JUDGE
              • Jul 2010
              • 81
              The TV had low ESR KT brand to start with that went bad,so I replaced them with the following brands,and series.Rubycon MCZ,Rubycon YXA,Panasonic ED,Hitano EHR,Jamicon TR.So you really needed low ESR capacitors for the power supply to work right/at all,or just to make it last longer?Thank You very much!
              Tyler
                • 31137
                well YXA isnt low-esr, not sure about the others.
                you do need low esr on psu outputs.
                • 1supertech
                  • Apr 2012
                  • 384
                  [QUOTE=70JUDGE;124375]I have a Trutech PLV16260 LCD TV I have been trying to fix.It is over in the TV forum.I noticed a buzzing noise coming from the power supply.I traced it to a metallized polyester film capacitor marked 400V 105K.Is there any way of testing this?Are they supose to buzz?Thank You very much!
                  Tyler[/QUOTE
                  Can a metallized polyester film capacitor be checked with a esr meter?
                  just for future Knowledge.
                  • Longbow
                    • Jun 2011
                    • 623
                    The short answer to your question is yes, you can test a mpf capacitor. Of interest would be the schematic of your power supply, btw. I think you would be better served by having a look at what should be happening, instead of just blasting parts. More specifically, an ESR meter would probably not tell you much since the value is 1 uf. The quickest test is to replace the cap. A real test has to put working voltage on the cap, in this case near 400v. A capacitance meter (many multimeters have them built-in) will tell you if it is 1 uf, and a 400v. power supply with current limiting will tell you if the part is leaking. That is the actual "test".
                    Is it plugged in?
                    • 1supertech
                      • Apr 2012
                      • 384
                      Thanks longbow
                        Pulled a failed poly capacitor from a Yamaha amp, the amp would not power up.
                        Rated 22nF, measured... 6.5nF.
                        The failure mode is reduced capacitance.
                        And that's the only time I have used the capacitance range on my meter to diagnose an actual problem.
                          TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                          FF Series (Very Fast Acting), 0603 Size
                          Features
                          ● Very fast acting at 200% overload current levels
                          ● Low DCR
                          ● High inrush current withstanding capability
                          ● Fiberglass enforced epoxy fuse body
                          ● Copper termination with nickel and tin plating
                          ● Halogen free, RoHS compliance and lead-free
                          Applications
                          ● Notebook computers and tablets
                          ● Digital cameras
                          ● Memory cards
                          ● Toys
                          ● Bluetooth earphones
                          ● Portable electronic devices​...
                          10-07-2024, 05:50 AM
                        • jm1234
                          Yageo 400V 680uF measuring 580uF
                          by jm1234
                          I have a Yageo 400V 680uF that is currently measuring 580uF (Measured by UNI-T UT603). Does that normally qualify for replacement?
                          Details: Siemens tumble dryer getting Error 25 after an hour or so, on all last 3 runs.
                          I checked the circuit boards quickly and this capacitor sticks out, nothing visible, not even bulging though. It costs 12euro, so I'd like to get your feedback first. The main thing on that board seems to be a motor controller (for the compressor) https://www.mouser.sk/ProductDetail/...xvzUNHBQ%3D%3D.
                          Thanks...
                          01-12-2024, 10:13 AM
                        • WatchItFool
                          Sony FVS1000 film scanner telecine Roms
                          by WatchItFool
                          looking for ROM files / updates, software, and CAD files. Everything really
                          i have most, but not all, available documentation by sony pn.
                          What was all listed in the sony pro reference library?
                          I dont know of any places to look. will anyone name names?
                          08-04-2023, 12:58 AM
                        • Bowlsnapper
                          Need help fixing Samsung Slimfit tx-s2783
                          by Bowlsnapper
                          Okay. So I noticed that there is wiggliness in the top 1/4th or 1/5th of the screen. It relaxes and gets less wiggly when things warm up. From my research, that's horizontal deflection. So I recapped all the electrolytics. Pretty much any CRT is due for that. The colors and geometry got WAY better afterwards. Not bad for my first CRT recap. But even though everything looks better, the GOD DAMN deflection issue is still there. So I said okay, maybe these big brown film capacitors adjacent to the flyback are on the Fritz. So I remove one. Can't tell what 125j is because I have no electronics knowledge,...
                          08-05-2023, 09:59 PM
                        • knoxrebel
                          TCL 65s425 sound/video working, no backlight
                          by knoxrebel
                          Tv shows no issues other than no backlight. Picture was visible with flashlight and menu navigation possible with audible responses.
                          Polyester film Capacitor c620 27nf (on power supply board had visible brown discoloration, but is not shorted. Replaced with suitable spare and now working properly. (Apparently this is a known issue with this series.)
                          Backlights tested independently with tester and registered ~140vs on each.
                          40-L171w4-pwa1g
                          Mmkp82 1kv 273 J...
                          01-12-2025, 03:33 PM
