Cloning PIC chip 16C72A
  • mitsu2k
    • Aug 2013
    • 219
    Hello I am trying to repair a monster HTS 3600 mkII surge protector. I already know that one of the PIC chips is bad or corrupt. From what I can tell, this PIC controls the display, dimming, and possibly other features which are unknown to me at this point. All the outputs seem to be working as well as the remote input. I have another HTS 3600 that is working fine. My question is if I purchase a new chip (16C72A) and used a PIC programmer to read the chip from my good unit and write the code to the new PIC? Basically just cloning it. My concerns are I would hate to damage or corrupt the code on the good chip while trying to read it. I am also aware that the PIC might be protected to where I cannot read it at all or even worse, if there is some kind of fuse programmed in to blow or corrupt it if one tries to read it.
    Any thoughts?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Cloning PIC chip 16C72A
    You can try to read it, but usually it will read all blank or zeros if it's protected.
    I think most companies will turn on protection so chances of a good read are very low.
    • mitsu2k
      • Aug 2013
      • 219
      What is the likelihood that the chip has some kind of fuse setting to self destruct if a read is attempted?
      By the way, I plan on using a K150 programmer to read it if that helps. I know it's not the greatest programmer out there but was hoping it may suit my needs for this project.
      • redwire
        • 3910
        I would see how the factory programmed the PIC. Sometimes it's preprogrammed and then soldered in, or it has pads/header for programming on the main board you can connect to.
        There is no self-destruct in a '72A other than the problem of powering the IC - by the programmer or the surge protector doing it. Make sure the IC is not hazardous live, see if the circuitry is isolated from mains to prevent killing the programmer.
        If the software is straightforward (it's only 2KB) and the product is nothing as far as technology goes, I have seen the code-protect bit not set on a few products.
        • mitsu2k
          • Aug 2013
          • 219
          Wow that's good info. The chip is not soldered. It is removeable as it is plugged into a socket so its is easily removed to place in a programmer. Attached is a photo. My biggest fear is somehow messing up my good one trying to read it. But if it's pretty safe, I'm going to try. Are there any other things I should be aware of or be careful of?
          P.S. The reason I knew the model of chip is I removed the sticker from another one.
            • 31067
            if you have not worked with pic's before,
            there are 3 area's to read.
            main-flash,
            eeprom
            and fuses
            dont overlook the fuses because they set things like the clock settings
            • mitsu2k
              • Aug 2013
              • 219
              main-flash,
              eeprom
              and fuses
              Thank you. On the DIY K150 program, I see there is a read button and a Fuses button. How exactly do I read the 3 areas?
                • 31067
                i have no idea - i'v never heard of a k150
                got a link?
                most people use a pickit2/3 because the clones are soo cheap, or they buy a TL866-II+ < dont buy that btw,
                it's beed discontinued and replaced by the T48 for the same price!
                • mitsu2k
                  • Aug 2013
                  • 219
                  got a link?
                  Do you know where I can get a pickit2/3 at a decent price?
                  Sorry here is a demo link
                  https://www.youtube.com/watch?v=4F8n1tQf4hw
                  Here is a link to the software
                  https://www.bristolwatch.com/k150/K150.rar
                  • mitsu2k
                    • Aug 2013
                    • 219
                    Update: Well, I received the programmer and attempted to read the chip but the results came back all 0s. Looks like it is protected. Guess I’m out of luck. Darnit!
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                      How to add chip support to NeoProgrammer software for the CH341A Programmer
                      by SMDFlea
                      Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                      and once you do find them there`s a few crucial steps missing.
                      Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                      Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                      After adding the chip save the xml file and copy it to the root directory of the...
                      05-26-2024, 07:15 AM
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
                    • hotcrossedbuns999
                      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                      by hotcrossedbuns999
                      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                      3. I could only locate two chips that look like bios chips. Could someone verify this
                      01-03-2025, 12:32 PM
