Mitsubishi CNC switching power supply board dead / relay board bad diode failure
    • Jul 2011
    • 6069
    Re: Mitsubishi CNC switching power supply board dead / relay board bad diode failure
    Originally posted by redwire
    The Rifa caps have clear epoxy that cracks and they bulge too. Even new old stock sitting in a parts bin, I had some that got plump and cracked.
    That looks like C4, C5 4,700pF Y-caps. I replace them on sight - many incidents where they short and burn because they are on mains. But you have a fuse so any damage would be limited.
    They are metallized paper dielectric. You can still buy them as PME271Y series like P271HL472M250 LS=10mm. I'm using Kemet or Vishay instead.
    Big X-cap C3 is a different make but these go low value with age, so I would test as well. The board has no MOV's and I think these caps help a little with mains spikes. Their EMI filtering is kind of ignored.
    How do you look these on DigiKey I have never looked for this type of capacitor before so any help would be appreciated thanks
    • redwire
      • Dec 2010
      • 3912
      Digi-key, passives, film capacitors. 85,051 Results.
      Then input what you know like: mounting type through-hole, 4,700pF or 10mm lead spacing, Ratings any Y1 or Y2, in stock... down to 42 results.
      Mouser has a checkbox for "safety capacitors" which makes it easier.
        • Jul 2011
        • 6069
        Okay thanks
        • InsertCoin
          Relay Satronic MMI 810.1 bad diode & Transistor
          by InsertCoin
          Hello and happy new year ,
          my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
          There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
          The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
          I have made a diagram of the PCB and some measurements along some...
          01-16-2024, 05:47 AM
          DVR camera recorder switching power supply capacitor failure really
          These cheap non brand capacitors at it again
          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
          Well at least I have the cameras back on line I to try the...
          01-22-2022, 06:28 PM
          DVR recorder Switching power supply Failure
          When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
          Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
          This...
          05-27-2023, 03:03 AM
          07-01-2024, 06:34 AM
          12 volt switching power supply modification to 14.5 volts before blocking diode add
          I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
          I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
          One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
          04-11-2021, 11:01 AM
