Reflow equipment
  • tony359
    • Oct 2018
    • 266
    • United Kingdom
    Reflow equipment
    Hello all,
    I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
    I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
    Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably, burning the whole thing.
    I'm aware my SMD station is awful at blowing an even stream of air out of those large nozzles so I made a little "propeller" modification to the wand (which I think it's now standard with the newer version) but still it did not work.
    You can see from the pic below a test I did when brand new before installing my mod, you can clearly see the unevenness of the temperature on the internal grille
    I tried with my largest round nozzle and it worked like a charm, but when I attempted to reflow the CPU, which is a bit larger than the chipset, I couldn't really reflow it properly.
    I have two thermocouples which are monitored by a laptop and also an IR thermometer to monitor temperature. I wait till the board/chip is 180 degrees, then I apply hot air (set to 310 degrees) to reflow. I see many people online using much higher temps on their hot air machine but that's without a pre-heating plate and I'd like to keep the temps as low as possible to avoid damaging components.
    Now, I appreciate the proper way to reflow a large chip is NOT by using a hot air station. However, I don't want to invest in a proper reflow machine simply because I won't be using it a lot.
    The question for the community is: is it worth investing in a better hot air machine, one which delivers a more even flow of hot air and also maybe one which has a higher flow available for using with those larger nozzles?
    Thanks for your input!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Reflow equipment
    Many hot air stations use hot air instead of IR for the top heater.
    Get yourself a decent hot air station like the Atten ST-862D or Quick 861D, they are more than capable of reflowing with 1200W.
    My Atten also makes removing HDMI sockets so much easier than my old hot air.
    • tony359
      • Oct 2018
      • 266
      • United Kingdom
      ah, interesting as hot air used as top element.
      Those seem to be within my budget - I see the Quick 861DE has 200L airflow which is probably more suitable for the larger nozzle, what do you think? (turns out my Aoyue is 23L/m so probably even the 120L model should do LOL)
      I'm watching Louis Rossman review of those
      • diif
        • Feb 2014
        • 6978
        • England
        Yeah, I don't have my speed past 30%.
        • tony359
          • Oct 2018
          • 266
          • United Kingdom
          what about larger BGA's? Shall I use the larger nozzle - which is basically the same diameter of the wand - and increase the flow?
          • diif
            • Feb 2014
            • 6978
            • England
            I'd use the 22mm universal nozzle that comes with some Atten kits, if i was using it for BGA rework. Have a practice with some scrap boards to work out the necessary temperature, distance and air speed to as closely follow a reflow profile as possible.
            • tony359
              • Oct 2018
              • 266
              • United Kingdom
              Indeed I’m experimenting with scrap boards and trying to folllow a profile I’ve set on an app which is monitoring the thermocouples- even though I found that an IT thermometer is more reliable. As you say, I think I’ve found a good combination of temperatures and air speed to make it work reliably - it’s just that when the chip is large, I feel that my airflow is not enough.
              I see the Quick machines have larger rectangular BGA nozzles available while the Atten don’t. I’d be tempted to get the 200L machine just to make sure it’s ok with larger nozzles - even though it’s a bit too expensive.
              I know that for smaller parts 200L are really not necessary- and maybe 120L are ok anyways - what is your thought?
              Thanks!
              • diif
                • Feb 2014
                • 6978
                • England
                You're lacking heat not airflow with your current station, it's the reason i upgraded from a hot air station like you have to the Atten.
                Some of the Atten stations come with a universal nozzle allowing for all of the super cheap nozzles to be attached.
                • tony359
                  • Oct 2018
                  • 266
                  • United Kingdom
                  I can reach 480 degrees with my station (I think?) but I'm trying to keep the temps as low as possible to avoid damaging the components - considering I have a pre-heating plate.
                  Using larger rectangular nozzles, I can barely feel any air coming out of them so I feel that my station is not suitable for them.
                  I feel that a bit more air and a larger round nozzle may be enough to reflow with more success. I am also well aware that blowing 200L/m air on a board will probably blow half of the components away!
                  Basically my question is: would I ever need more than 120L/m - this is imagining that I may want to reflow, say, a PS4 APU using the square nozzle which is pretty big?
                  And has anybody ever checked the temperature evenness of the air coming out of the Atten/Quick? The Aoyue tends to blow a massively uneven flow of air which makes it impossible to use with the BGA nozzles.
                  Thanks again for your input.
                  • Olvin1
                    Acer nitro 5 an517-52 reflow/rebal CPU
                    by Olvin1
                    I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
                    I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
                    • A detailed temperature profile for reflowing this specific CPU
                    • Step-by-step guidance for a safe and effective reflow process
                    • Tips on what to watch out for during the procedure
                    If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
                    08-01-2025, 01:59 PM
                  • G-Gamer
                    Please tell me where I'm going wrong with hot air!
                    by G-Gamer
                    So I'm trying to get into micro soldering, repairing tech etc.
                    I bought a load of equipment, The YIHUA 853D 2-in-1 station, 1080p Microscope with 10", I do not have low-melt or leaded solder yet, I have tried flux 'paste' in a tube, very liquidy seems to blow away, I've tried flux paste in a tub, still no luck.
                    I have tried 3 different boards, a router, an Xbox One Fat and now a Pi400, none show ANY signs of melting solder, components don't budge.
                    My method:
                    Preheat board with hot air (Small nozzle as it's directed, as I'm told) at 250c
                    Apply flux to component...
                    11-13-2025, 10:25 AM
                  • Mr_Nada
                    Concerns before attempting a Reflow of Laptop's GPU
                    by Mr_Nada
                    I saw some posts at one point talking about doing a reflow but I couldn't find them again so I thought that I would post this here.
                    I plan on reflowing the GPU of this old HP DV2500 laptop but I want to go over what I have and the steps I have to take to guarantee it will come out fine.
                    I have a Yihua 8786D 2in1 Rework station, flux (just some paste that I got from an old Radioshack kit), a couple rolls of Kapton tape and a $15 Thermometer +probe (a TM902C from EMR shielding Solutions if its important).
                    • The paper that came with the thermometer states that the probe
                    10-10-2024, 02:53 AM
                  • BOSCHNJAK
                    by BOSCHNJAK
                    ABOUT ME INTRODUCTION FILE
                    2
                    024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                    2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                    2022 BEV, PROJECT ?
                    2021 BEV, PROJECT ?
                    2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                    2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                    12-28-2023, 02:09 PM
                  • Davi.p
                    For BGA reflow experts...
                    by Davi.p
                    I have attempted all sumed very few reflow processes, and i need to make it better, how do you make yours to have sureness that the balls are really fully reflowed? My temptation was always to do "the slight move" touching very gently an angle, but due to some cases, but maybe 100%, where the previously half working device became totally shut off, i finally understood that the damn "move" makes the balls shorted, so what do you suggest?
                    Thanks!.. Muchas gracias.....
                    11-23-2024, 10:36 PM
