New Cheap Chinese Soldering Plates
  • redwire
    • Dec 2010
    • 3912
    Re: New Cheap Chinese Soldering Plates
    I think it's not about being new- it's about not wrecking your LED project or the board you're repairing figuring it out as you go, kind or thing. Some people use scissor jacks to lift up the board, off the plate to cool it.
    Originally posted by clearchris
    Link? Which one?
    I ordered this one, who knows if it will come in with Christmas rush and shipping backlog. Notice- shipping has been jacked up a lot on all stores last week.
    https://www.aliexpress.com/item/1005003391422040.html
    This Aliexpress store has many possible sizes, voltages, temperatures.
    • redwire
      • Dec 2010
      • 3912
      My hotplate came in and it was only packed in a bag (no padding) so the wires got slashed. Sigh. It's the larger 12x7cm/4.72x2.75 inch one.
      The standoffs have magnets in them which is nice, no label on the plate, the bag says 599235.02 400W led ptc BXBA-AX-BT but no voltage spec. anywhere.
      The PTC heater is weird, I measure 220Ω cold but plugging it in 120VAC it started drawing over 5A which is 600W and kinda scared me, it blew my 2A fuse. No fuse, readings I got:
      0 seconds, 0W, 220Ω, 25°C misleading PTC ohmmeter reading
      10 seconds, 460W, 31.3Ω
      30 seconds, 200W, 72.0Ω, 200°C
      115 seconds, 108W, 133.3Ω, 225°C
      125 seconds, 83W, 173.5Ω, 230°C
      So it settles after about 2 minutes to around 230°C. I'll try some M-core LED's soldering/rework later.
      I think the challenge is moving something hot off it, to a cool down area.
        • 31285
        dont use the magnets - when you heat a magnet the field drops
        • redwire
          • Dec 2010
          • 3912
          The magnets are at the far corners, on the feet. They don't get as hot. Not ferrite, it's some el-cheapo rare earth that are like candy over there. Many are good to >200°C so who knows.
          The heater resistance went back down to 220Ω when it cooled down BUT this morning it was 42kΩ
          If I push down on the plate it drops to a few hundred Ω, depending on where I push. So I thought it must be cracked... but plugged it in anyway. It's still working fine.
          So the PTC is non-linear it acts like a MOV it needs higher voltage to fully conduct. Good to know, it's not a resistive thing I would have been fooled by the ohmmeter reading. PTC must be made of zinc oxide granules.
          Either that or my plate is busted.
          • Ady2017
            SMD fuse soldering advice please
            by Ady2017
            Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
            11-07-2025, 12:03 PM
          • Azurain
            Elitebook 840 G5 Bios Chip Soldering Question
            by Azurain
            I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
            Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
            04-14-2023, 06:58 PM
          • rmjimenez455@gmail.com
            Sumsour station 8586D error H-E
            by rmjimenez455@gmail.com
            Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
            09-07-2024, 09:33 AM
          • blero
            Repairing cheap chinese Led bulbs
            by blero
            I'd like to try to repair these corncob shaped chinese bulbs with tens of Leds on them.
            I know they're bad quality and fail fast, because of the Leds or the capacitor(s).
            So I plan to try to replace the main capacitor 15uF-400V with a good quality one.
            I've used in the past some capacitors of this eBay vendor which is well known on this site: egekecu. I'm still daily using a monitor I repaired with his products.
            I know it has been said he sells good and real brands but outdated capacitors. He's actually 3 times cheaper than RS-Online...
            01-31-2021, 07:06 PM
          • Peter_1402
            Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
            by Peter_1402
            Hi Everyone,
            I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
            1. Soldering iron works great
            2. There is a burnt mark on the hot air gun handle.
            I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
            Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
            Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
            Reed switch tested ok with a magnet.
            From the above test, I can conclude...
            07-12-2025, 11:50 AM
