New Cheap Chinese Soldering Plates
  • redwire
    • Dec 2010
    • 3900
    Re: New Cheap Chinese Soldering Plates
    I think it's not about being new- it's about not wrecking your LED project or the board you're repairing figuring it out as you go, kind or thing. Some people use scissor jacks to lift up the board, off the plate to cool it.
    Originally posted by clearchris
    Link? Which one?
    I ordered this one, who knows if it will come in with Christmas rush and shipping backlog. Notice- shipping has been jacked up a lot on all stores last week.
    https://www.aliexpress.com/item/1005003391422040.html
    This Aliexpress store has many possible sizes, voltages, temperatures.
    • redwire
      • Dec 2010
      • 3900
      My hotplate came in and it was only packed in a bag (no padding) so the wires got slashed. Sigh. It's the larger 12x7cm/4.72x2.75 inch one.
      The standoffs have magnets in them which is nice, no label on the plate, the bag says 599235.02 400W led ptc BXBA-AX-BT but no voltage spec. anywhere.
      The PTC heater is weird, I measure 220Ω cold but plugging it in 120VAC it started drawing over 5A which is 600W and kinda scared me, it blew my 2A fuse. No fuse, readings I got:
      0 seconds, 0W, 220Ω, 25°C misleading PTC ohmmeter reading
      10 seconds, 460W, 31.3Ω
      30 seconds, 200W, 72.0Ω, 200°C
      115 seconds, 108W, 133.3Ω, 225°C
      125 seconds, 83W, 173.5Ω, 230°C
      So it settles after about 2 minutes to around 230°C. I'll try some M-core LED's soldering/rework later.
      I think the challenge is moving something hot off it, to a cool down area.
        • 30937
        dont use the magnets - when you heat a magnet the field drops
        • redwire
          • Dec 2010
          • 3900
          The magnets are at the far corners, on the feet. They don't get as hot. Not ferrite, it's some el-cheapo rare earth that are like candy over there. Many are good to >200°C so who knows.
          The heater resistance went back down to 220Ω when it cooled down BUT this morning it was 42kΩ
          If I push down on the plate it drops to a few hundred Ω, depending on where I push. So I thought it must be cracked... but plugged it in anyway. It's still working fine.
          So the PTC is non-linear it acts like a MOV it needs higher voltage to fully conduct. Good to know, it's not a resistive thing I would have been fooled by the ohmmeter reading. PTC must be made of zinc oxide granules.
          Either that or my plate is busted.
          • Azurain
            Elitebook 840 G5 Bios Chip Soldering Question
            by Azurain
            I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
            Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
            04-14-2023, 06:58 PM
          • blero
            Repairing cheap chinese Led bulbs
            by blero
            I'd like to try to repair these corncob shaped chinese bulbs with tens of Leds on them.
            I know they're bad quality and fail fast, because of the Leds or the capacitor(s).
            So I plan to try to replace the main capacitor 15uF-400V with a good quality one.
            I've used in the past some capacitors of this eBay vendor which is well known on this site: egekecu. I'm still daily using a monitor I repaired with his products.
            I know it has been said he sells good and real brands but outdated capacitors. He's actually 3 times cheaper than RS-Online...
            01-31-2021, 07:06 PM
          • rmjimenez455@gmail.com
            Sumsour station 8586D error H-E
            by rmjimenez455@gmail.com
            Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
            09-07-2024, 09:33 AM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • valente222
            help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
            by valente222
            Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
            05-12-2025, 03:42 PM
