Soldering - Desoldering issues
  • MXM
    • 430
    • Unknown
    Hello all...
    preambule.
    i used to do a lot of soldering/desoldering back in mny school days and in other jobs, now i have to get hands to work again since no one else is gonna do it around here,
    now i got a lot of those Nasty hp d530 sff going all boom!... sometimes the psu sometimes the mobo... my issue here is related with the mobo... i have found very hard to desolder some (just to not say all) the caps that regularly get blown...
    i have to use some not recommened old school tricks... at the end the job gets done but i dont feel like i should rely on those not-so-ortodox methods (i have gone to the point of using the hot air gun, to desolder a cap!)... specially because i might get things worse eventually at some case.
    anyways, i thought of this as a good start point to people with such problems, from noobs to experts... we could all use tips for improving this, i guess......
    im thinkin on getting a new solder roll... but not sure what should i look for, and the extractor wel ive never had problems with em but for some reasons on this mobo they are giving me hard time...
    anything is appreciated, peace.
    btw... ive been a not-so-active reader and then member but ive enjoyed this site from long ago
    peace.
    We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
    • 31198
    Re: Soldering - Desoldering issues
    put some 60/40 crap solder on the joints - it lowers the melting point of the original lead-free solder.
    • mathog
      • Mar 2010
      • 2655
      Or at least it makes a very good thermal connection to it, which also helps melt it.
      On a related point though, with most of the circuit boards now using lead free solder, might it not be best to also use lead free solder to attach the replaced components? And if so, which lead free solder is most likely to match what is on the circuit board? There are a bunch of different mixtures available, and it isn't like the old days when the only question was the ratio of lead and tin in the solder. Boards have stamps on them to indicate they are lead free, but never which type of solder was used.
      What I'm most concerned about is that the mix of lead free and leaded solder may not be at all ideal, and could be more prone to cracking or other failure than either type pure. See
      http://en.wikipedia.org/wiki/Solder#Lead-free_solder
      the section about how bismuth interacts with lead. Lead containing solder is certainly easier to work with than the lead free stuff, but mixing the two may not be great for the long haul...
        • 31198
        i only use lead-free solder.
        you dont need to "match" solders.
        there are 2 basic types of lead-free,
        with silver.
        and without silver.
        with silver flows much better and has a melting point about 10' lower.
        usually 217'
        the bad, it costs about 50% more.
        the other question is flux.
        there are several types.
        the main ones being "no clean"
        that you dont need to clean and leaves almost no residue.
        and "mild activated"
        this is agressive stuff that can solder to metals that can otherwise be a problem.
        however, it often leaves more of a mess, and you *must* clean it afterwards because it's corrosive.
        there are others such as "aquatic" and "highly activated" but you want to stay away from that stuff.
        imy personal fav is silver loaded with no-clean flux .7mm
        http://uk.farnell.com/metaux-blancs-...50g/dp/1689792
          Multifix 425-01 and 450-01 Rework Flux Datasheet
          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
          - No Clean Formulations
          - Low residue
          - Range of activity to deal with different component solderability
          - Halide free
          - Suitable for dispensing
          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
          Both products are supplied in syringes or cartridges for application by dispensing....
          10-07-2024, 06:02 AM
        • Nagyesz
          Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
          by Nagyesz
          I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
          All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
          How can I extend its lifespan? Could reflow help?
          It has ryzen 5 5500h, rtx 2050, no soldered ram.
          Example of the artifacts:
          03-01-2025, 11:11 AM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • corrize
          Desoldering - soldering BGA chip close plastic mini fpc connectors ?
          by corrize
          Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
          There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
          I have :
          - hot air, and a
          ll stuff around
          - true kapton tape
          - 140 and 180 degree soldering paste
          - bismuth
          - little hot plate 250 degree max
          - the new BGA chip with probably
          05-20-2025, 01:26 AM
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
