KSGER 2.1S Solder station Capacitor question - Temp rating
  • Urshurak776
    • Jul 2021
    • 6
    I have a spare power supply board and want to replace the three main caps. The 400V 82uf and the two 1000uf 35v caps. I have a Nichicon 400V 82uf cap at 105C (o issue with these) and two Rubycon caps at 1000uf 35v, however, these two are 85C caps. The ones on the board (even though junk caps) are rated at 105C. Could I use the 85C Rubycons in this unit?
    Thanks for any insight. I posted this on the eevBlog forum also.
    • 31010
    Re: KSGER 2.1S Solder station Capacitor question - Temp rating
    no, you need low esr type caps
    • Urshurak776
      • Jul 2021
      • 6
      Oh no......
      Thanks. The 400V 82uf has a low ESR rating. The 1000 uf ones don't have any ESR rating. Part number is 35PK1000MEFCCE10X20.
      Back to the drawing board on these. These 1000uf 35 V caps in a 10mm X 20mm package are hard to find.
      Appreciate the response.
      EDIT: I do have some Sanyo 1000uf 35V Low ESR capacitors in the right size package. I may just stick with these if I can't find a Rubycon or Nichicon in the right size. I'm sure these are still better than the Cheng-X that's in the power supply now.
      • redwire
        • Dec 2010
        • 3907
        The caps were already talked about in this thread
        • Urshurak776
          • Jul 2021
          • 6
          Thanks. Looks like the Panasonic FS series is the ticket. I’ll grab some.
            • Jul 2011
            • 6039
            Why not use KZE or KY or ( LXZ or LXY which are automotive grade which would work very well
              • 31010
              in 10mm??
              i think we did a search for 10mm caps before and only the pana's were that small.
              • Urshurak776
                • Jul 2021
                • 6
                I grabbed (4) of the Panasonics. I'll report back. Thanks all.
                  • 31010
                  your lucky, i can only buy those in 10's
                  • myth77
                    UV solder mask - high temp resistent, recomendation?
                    by myth77
                    Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                    Is there any solder mask...
                    03-28-2022, 04:04 AM
                  • redwire
                    KSGER T12 station shake switch hassles
                    by redwire
                    Ongoing hassles with the shake switch on my KSGER T12 station. In standby, the slightest movement of the workbench would wake it up.
                    Handle has the SW-200D two ball switch, I had installed it gold lead down towards tip/silver up, so it was N.C. when in the stand.
                    But any tiny jiggle and the station would wake up. I think the firmware looks for a rising edge on the signal to wake up.
                    So I took the wand apart and flipped the switch around. Turns out soldering the plastic it melts super easy deforming the end. It totally did not work afterwards, killed the switch. ...
                    02-14-2023, 02:07 PM
                  • Crystaleyes
                    Tenma (Farnell-rebranded) 21-10115 solder station question
                    by Crystaleyes
                    Olá.
                    Looking for some help clarifying something.
                    I have a Tenma (Farnell-rebranded) 21-10115 solder station which recently burnt out the ceramic element.
                    The station is 60W / 28 volts, 110v.
                    Right now I'm in Brazil and finding an equivalent element has proved to be not possible, so today I bought a 'Yaxun' 50W 24v iron in the hope that it would work.
                    Both irons have a five pin plug.
                    The Tenma had pins 1 & 2 and pins 4 & 5 shorted with pin 3 being the ground. No means of measuring the temperature.
                    10-19-2021, 08:08 PM
                  • servis jaya.comp
                    Quick 857D Solder air station firmware
                    by servis jaya.comp
                    Hi All...any One have firmware for Quick 857D hor air solder..please share ..
                    Thanks..
                    06-13-2024, 08:35 PM
                    HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                    This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                    09-12-2024, 02:20 PM
