Would anyone recommend this “ UNI-T 260B Thermal Imager” feedback wanted
    • Jul 2011
    • 6027
    I saw a review for this UNI-T 260B Thermal Imager and his review was positive but I would like to know if anyone on this forum has used and what they think about its quality and how easy it is to use
    Or this model
    UNI-T UTi85H Infrared Thermal Imaging Camera 30℃ - 45℃ Infrared Thermometer
  • brethin
    • Dec 2008
    • 1907
    Re: Would anyone recommend this “ UNI-T 260B Thermal Imager” feedback wanted
    You don't say why or what you want a thermal camera for so it's hard to help, generally they are a waste of $
      • 30950
      review:
      https://www.youtube.com/watch?v=h3Hu_op4mG8
      • ngml
        Repair of an LG split AC system indoor unit PCB
        by ngml
        I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
        This indicates an error in the communication between the outdoor and the indoor unit.
        The outdoor unit is fine, so the problem is the indoor PCB.
        The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
        I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
        Does anybody have the schematics of this board,...
        02-01-2025, 12:55 PM
      • nobbnobb1
        Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
        by nobbnobb1
        Hi guys,
        Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
        When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
        02-03-2022, 11:14 AM
      • ay_bulut
        UTİ 260B Thermal Imager
        by ay_bulut
        I need UNI-T 260b firmware
        03-21-2021, 04:08 AM
      • Gjackson
        Air-conditioning unit power supply failing to power up
        by Gjackson
        Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
        01-08-2022, 09:24 AM
      • navagator
        Hitachi Power Supply Unit Interchangeability
        by navagator
        I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
        Does anyone know if these 2 power supply boards are interchangeable?
        Thanks.
        01-08-2024, 07:53 PM
