PLCC84 package reflow post cleanup question
  • powrslave
    • Jun 2020
    • 6
    • usa
    What is the cleanup process for post reflow on a PLCC84 package?
    I'm worried about left over flux under the chip etc.
    Spray it all out with acetone/alcohol?
    • 31091
    Re: PLCC84 package reflow post cleanup question
    kitchen towel to absorbe/wipe away the isopropanol & flux
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • chth96
      Is it good to use chemistronic flux off es835b for flux remover?
      by chth96
      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
      11-17-2023, 07:25 AM
    • Olvin1
      Acer nitro 5 an517-52 reflow/rebal CPU
      by Olvin1
      I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
      I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
      • A detailed temperature profile for reflowing this specific CPU
      • Step-by-step guidance for a safe and effective reflow process
      • Tips on what to watch out for during the procedure
      If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
      08-01-2025, 01:59 PM
    • tony359
      Reflow equipment
      by tony359
      Hello all,
      I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
      I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
      Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
      12-25-2021, 01:29 PM
    • evilkitty
      Flux causing high resistance short?
      by evilkitty
      Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
      Temp is on the left humidity is on the right
      i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
      The pin out looking down from the top is (note this is common cathode)...
      07-17-2024, 09:38 AM
