"f6" "f7" blue esr issue
  • ewastecomputers
    • Jan 2010
    • 15
    i know this must be a stupid question but here is goes bought blue esr meter and built it was so fun. I am a novice-medium knowledge in repair person on a good day lol. yes this is my first kit since i was a kid.
    Now when i start her up all seems good, so i though i would do the self test feature on the meter so i read the info on how to do this properly so i did this
    (Before doing the self-test, it's very important to first set VR1
    to the center of its adjustment range, short out R30, 100R and make sure that the meter's supply voltage is
    in the range of 6.2 – 6.8V. Do not use a 9V battery for this test because it will cause a false F2 warning!)
    So i did and i got "f6" then tried it again and got a "f7" well i looked all over with a 10x glass to see if i created whiskers or made a bridge but as i see it all looks good. I installed a couple of trans backwards but caught myself and fixed them around do you think i could have fried them with heat??might have, will change them for fun. Measured all resistors and all seem to be in the right place. any help would be of great value..if you need anymore info just ask thank you for your time.
  • hardwareguy
    • Jun 2006
    • 405
    Re: "f6" "f7" blue esr issue
    Look up the assembly manual....the error codes and their meanings are included. Troubleshooting suggestions for each error code are in the book as well.
    • Toasty
      • Jul 2007
      • 4171
      Pages 11 & 12:
      Code:
      F6: No output from pulse amplifier.
      Check around C7 (33nF), R12 (1k!), D3 & D4 (1N4002), C5 (100nF) and
      C6 (47@F bipolar).
      F7: Q3 not sourcing current.
      Check around Q3 (2N3906), R5* (2.2k!), R6 (10k!) and pin 15 of IC2.
      veritas odium parit
      • ewastecomputers
        • Jan 2010
        • 15
        Ok i will go over it again i may have missed something. i will re-solder the joints you think "yes" around the areas........ will get back to you after again thank you for your time.
        • Toasty
          • Jul 2007
          • 4171
          Please post back with your findings. If this is unresolved, you can also join and post on the anatekcorp.com forums or contact Bob Parker (meter creator) here.
          https://www.badcaps.net/forum/member.php?u=3759
          Whichever way you decide, please update us.
          veritas odium parit
          • Krankshaft
            • Jan 2007
            • 2328
            I PMed you back regarding what to check.
            In the future its better to post on the forums you get more input that way.
            • ewastecomputers
              • Jan 2010
              • 15
              ok i have touched up any solder i have seen to be a problem but with the same issue f6 and some times f7
              • Toasty
                • Jul 2007
                • 4171
                Biggest problem with these kits is resistor markings (4 & 5 stripe) being confused and improper part placement -> transistor inserted wrong(backwards).
                Go back to the start of the manual and verify all the resistors first. Then check the diodes and transistors.
                veritas odium parit
                • ewastecomputers
                  • Jan 2010
                  • 15
                  i will and get back to you thanks for your time guys
                  • ewastecomputers
                    • Jan 2010
                    • 15
                    i have found the 100k and the 220k not testing their true values unless i am testing them wrong. 100k is measuring about 50k and 220k is reading about the same. i will replace and see what the result is.
                    • Toasty
                      • Jul 2007
                      • 4171
                      Something's wrong. You have to double check the color codes. These are mixed 4 and 5 stripe resistors. It is very easy to read from the wrong end and come up with a seemingly correct value. I did it, but I caught the error by double checking them with a ohmmeter before I installed them.
                      If these 2 are marked differently and reading the same, something is really whacked. Check your meter. Resistors -typically- fail upward in value. I've not seen one that was lower.
                      veritas odium parit
                      • i4004
                        • Oct 2006
                        • 2029
                        http://en.wikipedia.org/wiki/Electro...r_and_inductor
                        and you have a nice color-coded table a bit below there...
                        • Bobdee
                          • Jun 2008
                          • 461
                          nice and easy one here too that covers 4+5+6 band resistors
                          http://www.samengstrom.com/nxl/3660/...e_page.en.html
                          it does all the work
                          • Radio Fox
                            • Jan 2010
                            • 281
                            I assume you are testing them "in circuit" with a digital Ohm meter.
                            Looking at the circuit, I suspect the reason you are getting the same low reading across both resistors is that there is only a 220R between the hot end of R13 and +5V. The impedance across the +5V supply is probably relatively low, compared to the high value resistors you are trying to measure.
                            Having said that, even if the +5V was a dead short to ground, I would expect a value closer to 70k rather than 50k, as the 2 resistors would effectively be in parallel.
                            Try lifting one end of one of the resistors (or remove them completely) & measure them again.
                            ________________________________________________
                            Invisible airwaves crackle with life
                            Bright antennae bristle with the energy
                            • ewastecomputers
                              • Jan 2010
                              • 15
                              did that and they test ok, so that is one thing to check off the list. Has to be a different problem.
                              • ewastecomputers
                                • Jan 2010
                                • 15
                                ok i have checked it over many times and i am thinking it is the transistors new ones fix this issue should i post a pic on here of what i have done.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4953
                                  • New Zealand
                                  Yes, please post pictures and detail how you fixed it, good to see you got it working!
                                  -David VanHorn
                                  • ewastecomputers
                                    • Jan 2010
                                    • 15
                                    Still not fixed sorry about post before was typo.
                                    got new trans today and put in still same result.
                                    i dont know what to do..still f6 f7 error with r30 sh orted.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4953
                                      • New Zealand
                                      Sorry I can't say much about this, I don't have one of these ESR meters (yet!) so I don't really know much about it.
                                      -David VanHorn
                                      • Radio Fox
                                        • Jan 2010
                                        • 281
                                        Could you still post a couple of pictures. One for each side of the board.
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
                                          Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
