I have not been successful in tinning the tip (chisel) of this iron. It seems to repel the solder. I use the standard chisel tip that came with the iron.
My experience with this iron is that it works well only at the highest setting. Anything less and the solder refuses to flow into the joint. Just replaced a "nest" of 6.3v 1000uf caps on an old SOYO board and found the heat available was only just sufficient.
I seem to be getting good joints and have successfully recapped about 10 boards.
I like it when my solder joints resemble the factory joints, but I sometimes find the solder wants to flow onto the cap leads and not into the joint. This is minimized if I trim the leads to a short length before soldering in the new caps.
Do I need to service the iron in some way?
I also have an inexpensive 50watt needle tip iron, works well, but totally inadequate heat for attaching caps. I use my solder sucker on the front of the board, and briefly hold the needle tip on the solder in the hole on the back of the board. releasing the button results in clearing of the hole. I'm sure my technique will make a purist wince, but it's quick and effective, but perhaps removes too much solder.
Occasionally in tight locations I will use the heated pin technique. This seems to move the solder out of the way, but leaves it near the hole, so the new cap can use it.
Seems like a nice method but more fiddly
So please offer suggestions/criticisms of my soldering technique or lack thereof,
