KSGER 2.01 2019 controller problem
  • cosmin1
    • Apr 2020
    Hi.
    I just received this KSGER controller from China, already defective.
    Actually it still works, but the STM32F101 processor it heats to 100 Celsius right after power on.
    Is there any chance to copy the firmware to a new STM32F101 and replace this one?
    Any advice is welcome.
    This is the model: https://www.aliexpress.com/item/3279...52084c4dbvpWaY
    • 31090
    Re: KSGER 2.01 2019 controller problem
    contact the seller for a refund.
    • cosmin1
      • Apr 2020
      I already did. But he moves very slowly. For almost a week i try to send him the video and still didn't receive it. I'm afraid to open case because Ali usually is on the seller side and is possible asking to send back for a refund. And the shipping to China costs more than the product itself.
      • redwire
        • Dec 2010
        • 3910
        That looks close to a KSGER 2.1S controller (without pump control mosfet option) which used STM32F103C8T6. The "version" number is usually on the OLED side of the pcb. Not 2.01, that used an LDO.
        KSGER 2.1S schematic here.
        Check the 3.3V rail is OK. I would wild guess the MCU has an output that is on and shorted to pcb, making the MCU run hot. The chinese play games to copy-protect their pcb from their countrymen ripping off the boards. They move an I/O pin, or have a "special" one grounded.
        Check the STM32F101RB MCU unused pin connections - some might be tied to +3.3V or GND with that port is assigned to output i.e pin 28 is odd in your picture?
        I have seen KSGER controllers with pin configuration wrong, like they screwup CubeMX or something. And of course sell those controller boards .
        You'd have to check the Russian sites for firmware, and they also have the key-gen needed to activate the KSGER firmware.
        • cosmin1
          • Apr 2020
          I identified the board as KSGER v2.1s r3, acording to dreamcat, here: https://github.com/dreamcat4/t12-t24...-and-Ve2.1S/r3
          Just my board is marked only as OLED. No other marks.
          I found the russian keygen, but not the firmware for this board...
          On-board R3/R6 (R2a/R3a on the schematic) from the voltage regulator feedback was not well soldered and i think the STM32 was powered at too high voltage unil i seen it. But now it's too late.
          The voltage regulator is just fine now, delivering 3,27V.
          The Vdd pins sould be connected inside, but i measure 3,27V on pins 48 & 64, 1V on pin13, 1,8V on pins 19 & 32.
          • kolebbk
            HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
            by kolebbk
            Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
            HP Endpoint Security Controller problem
            there is a problem with the hp endpoint security controller on the unit
            I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
            09-04-2024, 12:44 AM
          • fede77
            Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
            by fede77
            Notebook HP ProBook 450 G8
            ProdID 2K8L1LT#AC8
            Mother: DAX8QAMB8D0 REV D
            The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
            03-10-2025, 07:12 AM
          • lamonde
            850 G6 Endpoint Security Controller Problem
            by lamonde
            Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
            and there is no soud after flashing new bios, may be have some solutions?
            ProdID: 4YD62AV
            SN: 2TK9500V8X...
            01-15-2025, 09:31 AM
          • Voyager65
            HP 800 G6 Deskop Mini - Endpoint Security Controller Problem
            by Voyager65
            I got a used HP and see this well known HP Endpoint Security Problem Screen. Someone seems to have removed the password and reflashed the bios with (maybe) a wrong serial etc.. I was able to read and write with my programmer a new bios onto it - same problem. I tried a downgrade, same.
            I did password removal wir rcunlocker on several other machines without any problem. But this one is/was killed before. Appreciate any help.
            SN: 8CC1120Z0V
            PN: 8WY18AV
            Bios Dump:
            Thanks a lot...
            01-13-2024, 04:58 PM
          • 11profit
            HP 830 G5 endpoint security controller problem
            by 11profit
            Hi, I have a problem with the "endpoint security controller problem" error, I heard that it can be fixed by changing the bios config, do you know what exactly I should change to make the problem disappear? Desoldering and modifying the BIOS does not help.
            I am attaching the config file in the attachment....
            03-30-2023, 07:15 AM
