KSGER T12 OLED - says ERROR or INVERT
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Re: KSGER T12 OLED - says ERROR or INVERT
    Never mind, I did not initially see the cutout in the stand for the steel wool. Although as is, it seems one would bang the tip on the stand before getting used to that angle.
    • redwire
      • 3912
      I find brass wool gives a shorter tip life, it scrapes off the plating, metal against metal. In our manufacturing plant, this was the case and techs were actually throwing the brass wool in the garbage because it kills tips fast.
      A moist sponge has always worked the best for me, as long as you don't make a steam bath. "thermal shock" for a piece of plated metal does not bother it.
      The T12 soldering stands have all the wrong dimensions - many mm gap so the handle droops or falls out. This machined aluminum one is stupid expensive, the tip hits hard, nothing to catch it from falling out, usual crap design.
      Russians made some mods of a cheap stand.
        • 31199
        brass wool is fine,
        but a lot of the cheaper stuff is brass or yellow-coated steel!!
        steel is to hard - brass is soft.
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          Interesting. I have had the opposite experience. I had a 936 (knockoff of the hakko 936 but the "high end" kind of knockoff if you can call it that ) heater element die on me and a few tips that got oxidised because of plating cracks when using sponge. I did get good millage out of it though.
          I switched to T12 and brass wool. I still haven't had a dead tip or bad tip in years.
          I would guess it also comes down to how the brass wool is 'packed'? Having it loosely or tightly packed in its container would act differently? (analogues to different grit sandpaper)
          Very true and very frustrating to use!
            • Jul 2011
            • 6065
            I have the one on the left is the one on the right any better and is it worth the money
            I bought one also the angle is not correct and the opening is to wide to keep the soldering iron in place it a shame that it not made correctly because to me it would be a nice stand otherwise
            I have use the brass wool and have not had a problem as such but if you clean your tip a lot it does slowly wear out your tip but I tend to run my tip a little bit hotter than maybe I should ( also have to clean the tip more often because of the higher temperature setting ) but I do not want to burn traces off the boards so there is a trade off which I willing to accept
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              #26
              If you swapped to T12 and brass wool at the same time (that's how the sentence reads grammatically), how can you come to a conclusion that the damp sponge (vs crap soldering iron bits) was causing you problems previously?
              Follow me on YouTube
              Learn Electronics Repair
                • 31199
                another question,
                how are you all using the wool?
                i wipe the tip across it, i dont stab it into the pot.
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  #28
                  My bad, I was sleepy went I wrote this. I did repair my 936 but switched from sponge to brass wool. I had a similar tip (from same batch as the bad one). Never had any issue.
                  I switched to T12 at a later stage but kept using brass wool. I now keep the 936 as a back up.
                  • Spider1211
                    • Oct 2019
                    • 532
                    • Mauritius
                    #29
                    Originally posted by stj
                    another question,
                    Light stabbing on the 'loose' part of the wool. I used to wipe but sometimes solder would fly off.
                      ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                      This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                      09-07-2024, 04:30 AM
                      Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                      This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 07:12 AM
                      Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                      This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                      This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 06:40 AM
                      Gigabyte AERO 16 OLED BSF-73US994SH Notebook Specification for Upgrade or Repair
                      This specification for the Gigabyte AERO 16 OLED BSF-73US994SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-73US994SH boardview and 16 OLED BSF-73US994SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 06:38 AM
