FBTest by Mike Klykov
  • i4004
    • Oct 2006
    • 2029
    few days ago i got this and made few videos and pics:
    http://www.youtube.com/watch?v=CRAbAbFBXXE
    http://www.youtube.com/watch?v=t5Yrr_xrtvY
    http://www.youtube.com/watch?v=0C10xzUdbTk
    and better versions of last 2(ffdshow to watch)
    http://www.mediafire.com/file/yztmj2mztnh/fb_.avi
    http://www.mediafire.com/file/mcgmimonugm/fb_2.avi
    few pics attached.
    i'll also upload pdf by bob parker(original creater of this device) and anatek pdf of simillar device.
    mike's page
    http://www.radiofan.ru/fbtest/fbtest.htm
    pdf
    https://cdn.badcaps-static.com/pdfs/...78389b3cda.pdf
    translation of pdf
    and a quick rundown of how it's operated/what it does:
    you turn it on by shorting probes...first thing it shows is battery voltage
    ("Luminous 4th red LED corresponds to 2.6, 1 st green - 2.7V, 2-nd Green - 2.8V, 3rd green - 2.9V and 4 th green - 3B. By reducing the supply voltage below 2.7V recommended to replace the battery")
    then it does "runing-light" and then first led lights to mark device is ready.
    then you connect it to winding you wanna test and see what led(s) is lit.
    this devices applies pulse to the winding and then measures how much it "rings". more rings=better. number of rings=number of lit leds in case of bob parker design, and here there are only 4 leds but each can do red and green, so we again arrive at 8 possible states.
    as you can see above in the video this also works for trafos in smps psus, and even the feedback winding of +5vstby trafo produces some ringing(although only one ring).
    it seems this can be used for some coils too, but good coil won't necessarily lit green leds, because it's ringing may be too small because it has too small "q factor". so testing known good against suspected coil should help in such cases. for some coils it probably won't work at all. ie it'll show short-circuit state.
    overall a pretty nice device to help those "vintage" crt devices when flyback trafo is suspicious...and also trafos in smps psus
  • MiG
    • Jan 2009
    • 28
    Re: FBTest by Mike Klykov
    To pravi i Proko Pronalazac u Srbiji, mnogo pre tog iz 2008 i jos mnogo toga:
    http://tvproko.page.tl/Checkeri.htm
    A jedne od najboljih testera kondenzatora: ESR meter i Farad meter radi lik iz Cuprije...vrlo precizan i kvalitetan, jedan deo razvoja uredjaja je sam radio a druge je kopirao...takos to pravi za 50e a klase je 200e
    few pics attached.
    mike's page
    pdf
    translation of pdf
    • MiG
      • Jan 2009
      • 28
      Prosledi mi mail na mig@verat.net pa cu ti poslati datasheet za ESR and F meter
